New Car Build
Old August 10th, 2007, 04:42 PM   #1
exploderpilot is on a distinguished road
New Car Build
Ok,
I'm an offroader looking to break into the fox body game. i want to build a 92ish coupe, making around 400 to the wheels. any one who knows the roadmap to that goal, help me out here! tell me what i need !!!!
Old August 10th, 2007, 05:19 PM   #2
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
400 is a good number but its going to take some good amount of cash and time. i would say stroke it out to 347 get a nice top end set. cam, heads, intake, and i would say go carbed, maybe a nice demon 4bbl or edelbrock. good set of headers nice exhaust system youll def be there even beyond it...then you need to worry about suspension tranny so its going to be a long path..you can easily stay with a stock bottom end and upgrade the top end..edelbrock has some nice kits for the top end that run around 1500..nice suspension nice exhuast.. and short shifter a few minor upgrades and some nice wheels..youll have some nice times at the track and it will still be a good cruising car. im guessing your not looking for a monster track killer..lol..just a nice street car..if thats the case just upgrade the top end, tune it fully, make sure compression is nice..youl have fun..just shop around and dont settle for the cheaper way out youll jsut end up having to start over again and spending more money..just shop at jegs.com summitracing.com they always have nice deals there..good luck and welcome to mm
Old August 10th, 2007, 05:21 PM   #3
btw!!! youll learn a lot of info on your way while building the car..youll learn a lot here and a lot on your own so take it one step at a time and youll have a nice car...internet is the key to everything..lol
Old August 10th, 2007, 05:34 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
400hp is easy, pullies, exhaust a good cam, and a good fuel pump, then spray 200hp at it and piss off the guys with semi-built engines.
Old August 10th, 2007, 05:44 PM   #5
i know this might piss off some of the traditional style guys, but i was thinking about spending a big chunk of cash on a bulletproof bottom end, and then going with a small turbo setup, so i can reach my goal in a reasonable amount of time, but when i do have the money, i can go monster style without yanking blocks and starting over. make sense?
Old August 10th, 2007, 05:46 PM   #6
Here's what i was looking at starting with:
AD Performance Dominator 331 Shortblock
$4,495.00
AD Performance Custom Race Engine
DART Sportsman Billet Cap Race Block
3.25 Forged Crankshaft (Scat, Eagle)
5.400 H-beam connecting rods (Scat, Eagle)
Probe Forged 2618 pistons, Flat top or Dished (Optional: JE, SRP, Ross, CP, Customs.)
Clevite Race Bearings
Moly File fit Rings, please specify boost level or application
Balanced within 1 g, bored 4.030, torque plate honed, align honed, full block prep work
Blueprinted
Assembled
Heads, camshafts, oilpans and other options available.
We do NOT shortcut our engines! Every engine is custom made for your specific application and is FULLY machined and professionally assembled one at a time.
In basic form these engines will support in excess of 800+hp. With several small upgrades these combo's will support 1200hp! We can fully customize this engine to your brand and application specifics, this is an example of our common build, please inquire for specifics.
AFR heads,
Holeset turbo.
Old August 10th, 2007, 06:23 PM   #7
TurboLX's Avatar
1988 Mustang LX Turbo
What size turbo?
Holset HX35?
HY35?
HX55?
Old August 10th, 2007, 09:51 PM   #8
or you can spray it too..lol..like jbigbootsy said..thats an easy way
Old August 11th, 2007, 07:22 AM   #9
tording92lxnotch is on a distinguished road
If you want to turbo it why build the motor? You can make a pretty much stock 302 with a turbo make 400 hp no problem. In fact they are a great platform for boost because of the 9:1 CR and if its a pre 93 motor the forged pistons. Really the only time you need to build the motor is if your going above 500 hp really and thats because of the block mainly. The block is by far the weakest part of a 302.
Do a nice heads/Cam/Intake setup and a small 5 or 6 psi turbo kit and you will see 400 hp easily. You probably could do a stock heads/cam/intake and run like 12 - 14 psi and make 400 pretty easily too. Will just take more boost to do it with the stock top end. Good Luck
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old August 14th, 2007, 01:08 AM   #10
i definitely appreciate the inputs! you guys are gonna save me a lot of money....
Old August 14th, 2007, 07:04 PM   #11
www.quicktimeturbosystems.com
His base kit, about $2900, has enough power to split your block in half if unleashed!
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old August 14th, 2007, 10:25 PM   #12
baine21225's Avatar
or how about you buy your block, get the turbo setup, and spray the damn thing . . . . i'd be impressed
"Whip out your dick you'll either get it sucked or get smacked..."
Old August 14th, 2007, 11:24 PM   #13
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
What would he use the two engine halves for? Doorstops?
EDIT: Ooo! Wheel chocks, that'd be ironic!
Old August 14th, 2007, 11:45 PM   #14
1987 ford mustang gt
well see when shes done
That would make a perfect wheel chock,I dont think anything could roll over half of a 302 block .
347, torn apart again.
Old August 15th, 2007, 02:53 PM   #15
baine21225's Avatar
....or you could do that
Threads Similar to: New Car Build
302 Build 83five0 5.0 Mustangs 4 September 30th, 2007 03:17 PM
01 GT build WAR-PARTY Pictures 5 July 15th, 2007 01:25 PM
306 build up 92mustanglx 5.0 Mustangs 12 June 7th, 2007 12:46 PM
just about to build fastpony V6 Mustangs 11 December 30th, 2006 02:59 AM
Would you build or buy? ryanhewett466 5.0 Mustangs 5 June 19th, 2006 12:34 AM
