Low Oil Light
I have driven my 5.0 conversion about 75 miles and it is running good. Within the last 5 miles, the low oil light came on. The oil level is good and it has good pressure. I want to try to trace the problem, but haven't found a definitive answer if low oil signifies low oil pressure or low oil level. Does anyone know for sure?
Thanks
Current Mustangs: 2004 Cobra Convertible 1993 5.0 LX Hatchback 1992 5.0 LX Convertible |
what is the pressure gauge reading..if thats all wacky it might be a oil pressure sensor.
I probably should have mentioned that
Stock oil pressure gauge does not display anything, but the previous owner removed the needles to install white gauge faces, so I assumed it was a related problem. Voltmeter doesn't register anything either. We took the oil pressure sending unit out temporarily and hooked up a mechanical gauge, it shows 40-60psi.
Why not pop the hood and take out the dipstick and check the oil?
That is the first thing I checked, oil level is normal.
Low oil light is actually refering to the amount of oil in the pan. If you jack the car up and look there is a sensor sticking out of one of the sides of the oil pan in the rear sump. This is the sending unit for that light. Its pretty common from what I hear for this sensor to go bad and send a faulty reading to that idiot light. It has nothing to do with low pressure, just oil level in the pan.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
Threads Similar to: Low Oil Light
| Head Light and Tail Light Opinion Needed | Laser | Visual | 8 | January 2nd, 2008 03:16 AM |
| od light | 99bluev6 | Modular Mustangs | 12 | September 9th, 2007 11:01 PM |
| light bulb in dome light | myeleanor | 2005 - 2010 | 7 | August 31st, 2007 04:34 PM |
| ABS light | j2000_guy | 94-95 | 3 | March 29th, 2007 01:42 PM |
| How you can change your dome light color. (light on roof) | SonicStang | Visual | 25 | March 23rd, 2007 01:39 PM |
