underdrive pullies
Old July 15th, 2006, 06:06 PM   #1
militarygt's Avatar
militarygt is on a distinguished road
underdrive pullies
i need some help getting the alt. pullie off. any tips would be great.
Old July 15th, 2006, 06:10 PM   #2
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Very carefully Find some way to keep the pulley from turning so you can loosen the center nut.
Old July 15th, 2006, 06:27 PM   #3
mdvaldosta's Avatar
11.47@120.58
Gotta use an impact, either that or try loosening the pulley with the belt still on.
Old July 15th, 2006, 06:29 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yep, use an impact and it will be a walk in the park.
Old July 15th, 2006, 06:32 PM   #5
militarygt's Avatar
ya i figured i would have to use an impact. just hoped i wouldnt have to resort to that.
Old July 19th, 2006, 11:02 AM   #6
mikes93fox is on a distinguished road
If you don't plan on keeping the pulley in exchange for another then you can use a large pair of channel locks to hold in place if an impact is not available. I personnally would opt for the impact its alot easier than trying to hillbilly mechanic it.
93 vert - stock bottom end, AFR 165's, Crane 1.7 RR, F-cam, Ported Cobra upper and lower, BBK 65 mm TB, Pro-M 76mm MAF, FRPP 24lbs inj, Novi 1000, BulletProof AOD, Alum. rad, MSD 6a, Blaster 2 coil, FRPP 9mm wires, Holley 255 FP, 3:73, and Cobra R's
Old July 19th, 2006, 01:16 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The only problem with that is you usually can't get enough force to break the nut loose from the shaft and the shaft will just spin. An alternator that is fairly new or is on a car that doesn't see much moisture or road salt probably won't be a problem but anything that sees mother nature at her worst you can forget about. Up by me there is so much damn road salt still floating around even in the spring everything corrodes.
Old July 19th, 2006, 03:11 PM   #8
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I would recommend just using the impact and putting your old pulleys somewhere in a closet or something...They might come in handy sometime...
Facebook
Google+
Threads Similar to: underdrive pullies
Thermostat/Underdrive Pullies jbm5781 96-98 5 August 6th, 2007 11:23 PM
underdrive pullies ? droppedbass87 96-98 12 May 20th, 2007 10:18 PM
Underdrive pullies? mustang fanatic 2005 - 2010 13 February 5th, 2007 11:50 AM
BBK Aluminum underdrive pullies acmillr 99-04 6 January 16th, 2007 10:27 PM
Underdrive pullies Cricket V6 Mustangs 3 August 28th, 2006 10:28 PM
