Discussing running hot in the 5.0 Mustangs Forum. ok 85 gt 5.0, just replaced thermostat, got car running again, overheated, so i ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
running hotNORMAL is it true that the factory gauges only tell you if it's running cold or hot, but not in the middle, and if you squeeze the lower hose and there is pressure or you can feel fluid, the water pump works, Right???? and if you feel the same thing in the upper hose the thermostat is opening, yeah? Any help would be great, ???? |
if you have a clutch fan it could have a bad clutch
1990 Mustang LX
9.36@143 mph
Did the gauge go past normal? I wouldn't worry about it being hot until it is past normal. What was the temp on the thermostat you pulled out? What was the new one?
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
i have no fan clutch, and no idea what the ther temp i pulled out was, but i replaced it with the only one available at the time a 195, but in az that is the only temp anyone is selling, and the only reason i know this, is i work for one of these "auto parts superstores" ..... it's no shop but gets me through the day...
Get a low temp thermostat (160-180) and a hi-flow waterpump. Both can be had for under $100 and should fix your cooling issues if you are all stock. If you have a handfull of mods you might want to think about an aluminum radiator.
93 vert - stock bottom end, AFR 165's, Crane 1.7 RR, F-cam, Ported Cobra upper and lower, BBK 65 mm TB, Pro-M 76mm MAF, FRPP 24lbs inj, Novi 1000, BulletProof AOD, Alum. rad, MSD 6a, Blaster 2 coil, FRPP 9mm wires, Holley 255 FP, 3:73, and Cobra R's |
try blowing out your radiator and condensor assy. . Like me, your in a high dust area and it collects very well in the radiator fins.
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
#7 | |
1990 Mustang LX
9.36@143 mph
no a/c so that cant be it, and i already have an aluminum radiator, so im thinking like you said and a 180 therm???
how long has the radiator been in? it doesnt take long to pack the radiator on the air side with dust and dirt.
I run the standard 190 with factory radiator and a/c, and i never see the needle go over halfway, and thats ONLY when its over 100 deg here.
check the radiator, my radiator looked fine but when i touched it it turned to dust so i kept touching it cause it was cool it just kept falling apart
Threads Similar to: running hot
| RUNNING HOT!!!!!!! | BLACKNIGHT5.0 | 94-95 | 37 | September 5th, 2007 03:27 PM |
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 9 | August 21st, 2007 12:44 AM |
| not running right | jkovacs60 | General Tech | 2 | August 3rd, 2007 02:13 AM |
| Bad running... | alabamastanger | 5.0 Mustangs | 4 | July 15th, 2007 06:25 PM |
| Just Got Done Running a 89 LX 5.0 | Bigb2000GT | 99-04 | 1 | March 19th, 2007 06:57 PM |
