FIRST TIME AT TRACK, NOW TRANNY PROBLEMS.
I ran my car for the first time at the track it ran a 14.2, on the drive bakc down the strip i started hearing some clanging goin on from the shifter area. car still shifts fine, clutch seems to grab fine, just hearing sort of a grinding noise while moving, even in neutral. When I hit a high rpm from any gear i hear a rattling noise. anyone have any clue as to what it may be. could that be a throwout bearing, or the flywheel?
MUSTANGS |
How did you launch?
EDIT: For that matter, how did you shift? |
you sure its the tranny? might be the rear end or even the drive shaft....when i took my car down the first time the guy who had the car before me had the drive shaft only hand tight and it dropped....made a cool light show......not really more expensive than cool
1990 LX hatch
check your drive shaft bolts.
Wouldn't the driveshaft continually make a rattling sound not just at high RPM. As far as launching I tached at about 1500 and dumped it, and shifted at about 5500.
MUSTANGS |
incase it matters I was speed shifting also
MUSTANGS |
so I checked the driveshaft, nothing wrong with that. Anyother suggestions?
MUSTANGS |
#8 | |
#9 | |
I was having the same problem. I had a bad bearing in my tranny. It is not to expensive to repair but can be a pain in the arse.
with this much horsepower it is hard to act maturely. |
I lucked out and my buddy has a spare t-5 but it came outta the 2.3. He said I'll need to use my bellhousing, a new pilot bearing and it should bolt right up. Sound about right? BTW he's givin it to me for $100 incuding an A/C condensor
MUSTANGS |
Is there any chance that a tranny problem would cause a car to "pop" from the exhaust while in 3rd gear at 2500 rpm? Please say yes, I don't need motor problems
MUSTANGS |
02 Mustang GT
Cant wait to find out
![]() iTrader: 1 reviews
unfortunately i dont think so
02 Mustang GT "We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals." |
any idea what that might sound like? maybe just a tune up?
MUSTANGS |
Sounds like the rear end.
WHAT IN THE REAR WOULD MAKE THE EXHAUST POP?
MUSTANGS |
I meant actual popping sound from the rear end. Also have you done any mods to ur suspension lately?
if you are hearing a rattling noise at high rpms it might be a bearing.. how many miles are on the car. and how hard did u launch.. and what rpms are u shifting at
I launched at 1500, shifted at 5k and haven't done any suspension work, Car has 128,000 miles
MUSTANGS |
#20 | ||
Threads Similar to: FIRST TIME AT TRACK, NOW TRANNY PROBLEMS.
| First Time To Track! | vigilante | 94-95 | 6 | November 11th, 2007 02:36 AM |
| First time at the track | Grabber427 | 2005 - 2010 | 24 | August 7th, 2007 12:35 AM |
| First time with the new car at the track. | ryans88gt | 5.0 Mustangs | 7 | July 25th, 2007 03:08 AM |
| track time | ironhorse | V6 Mustangs | 5 | July 13th, 2007 06:08 PM |
| First time at track Run | Garhfer | 99-04 | 2 | May 13th, 2007 11:01 PM |
