Turn Signals Problem
Old August 15th, 2007, 11:42 AM   #1
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
My turn signals work when they want to, then when they don't they stay solid and dont blink when I switch them on... I also tryed a new MFS switch and it did the same thing... Any help would be greatly appreciated thanks...
Old August 15th, 2007, 01:48 PM   #2
baine21225's Avatar
i had a similar problem with my headlights, i found that it was one of the wires in the connector that goes into the back of the steering column. it was only loose and wiggled about a 16th of an inch but thats what fixed it for me
Old August 15th, 2007, 04:57 PM   #3
hopper is on a distinguished road
this tends to be a problem i found with the light bulb itself.. check the connection at the bulb and make sure the receptical isn't full of unwanted shit. clean it an put some diolytic grease in there.
hope this helps
Old August 15th, 2007, 10:36 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
Have you looked at the plug in blinker module? Its only like $2 at any auto parts store (you know, they thing that makes that clicking noise when you have the turn signal on).
They flash based on the current flow. That is why when you have a burned out bulb, they flash really slow or not at all (not enough current to flash) and when you have a shorted or screwed up bulb, they flash really fast (too much current).
If you put the turn signal to the left and the front and rear turn signals light up at normal brightness but do not actually flash (and the same for the right side), I would replace the flasher module.
It is mounted in the fuse box and may require a 90 degree turn to get it out.
Edit: add a little more stuff I forgot about. Next time the turn signals stop working, try the hazards. They use most of the same wiring as the turn signals and will help you narrow the problem down based on if they work or not while the run signals do not.
Old August 16th, 2007, 09:12 PM   #5
ridebmxfbm's Avatar
the hazards blink good, but the turn signals dont they just stay solid...
Old August 16th, 2007, 09:50 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
From what I can see with the diagrams I have, the only difference is the actual turn signal switch and that $2 metal can flasher unit thing I described in the last post. Basically, if the hazards work, the wiring to the lights, the lights themselves are fine, if the turn signals come on but don't flash, you also know that the are getting power that way as well but just not flashing which also should eliminate your turn signal switch being bad. I'd say try the $2 flasher thing. Worst case, you are only out a few bucks.
Old August 19th, 2007, 01:34 AM   #7
ridebmxfbm's Avatar
Sry I toke so long to post again, there's no flasher module on the fuse box... whereelse could it be?
Old August 20th, 2007, 05:32 PM   #8
92_LX_5.0 is on a distinguished road
i had this problem several times with my fox body, replace your ignition swith....does the AC stop working?
Old August 20th, 2007, 06:42 PM   #9
ridebmxfbm's Avatar
idk I dont have a/c, but everything else is fine besides the turn signals they work when they want too, the hazards flash fine, but the turn signals stay solid when you put them on...
Old August 20th, 2007, 10:16 PM   #10
i am telling you, i thought it was really weird but try replacing the ignition switch....i took the cover off of my steering column and i put pressure on the ignition switch and everything would work, if i took pressure off, it would do exactly as you are describing...
Old August 21st, 2007, 02:43 PM   #11
ridebmxfbm's Avatar
I will try that thanks 92 lx.. I'll let you know how it goes thanks
Old August 21st, 2007, 03:07 PM   #12
nolife's Avatar
91GT, 88GT, 02GT
You have got to have a turn signal flasher module somewhere in the car, if it is not on the front of the fuse box, try the back of it or somewhere in the area. It is a shiny metal or plastic can device that is about just over an inch across and about an inch tall. Although this is of no use to you, the one for the emergency flashers is normally behind the glove box (it is a different model). These things do fail and 9 out of 10 times when they do, your turns signals light up but do not flash. It might not be the problem but I'd verify that before you did anything else.
Old September 4th, 2007, 10:41 PM   #13
ridebmxfbm's Avatar
I found a circular can flasher behind the fuse box and I changed it out for a new one, but still my turn signals do not flash they stay solid but my hazards flash...
Old September 4th, 2007, 11:22 PM   #14
neverfastenough1's Avatar
I believe this has come up before and that there is a seperate flasher for the hazards which is on the fuse panel and one for the turn signals which is in the steering column or under the dash, can't remember. Usually if it is a bulb out, the flasher will flash fast, and when the flasher is out it will come on and not flash.
Threads Similar to: Turn Signals Problem
TURN SIGNALS STOPPED WORKING!! HELP!! 1answer Modular Mustangs 7 July 8th, 2007 12:17 AM
Anyone Have Sequential Turn Signals? 96Snaker Audio/Video 18 March 18th, 2007 12:11 PM
Ranger Turn Signals Stan27 All Other Vehicles 8 July 30th, 2006 12:58 AM
Turn Signals todd5501 General Tech 4 April 29th, 2006 08:29 PM
