t-5 problem
Old August 15th, 2007, 12:50 PM   #1
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
t-5 problem
i have a t-5 trans and it grinds when going in reverse. it never did it before it just started to now. the car sat for like 4 months while i worked on it. it only started to grind once i drove it the other day. idk maybe the cluth cable is loose or something..idk what do you guys think.
Old August 15th, 2007, 01:19 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
All T5 transmissions do that, actually all manual transmissions do that because reverse is engaged without a synchro.
I guess if yours has never done that or has got noticeably worse above and beyond what is normal there must be something else going on. Some transmissions use various methods to stop the input shaft but I don't think the T5 has something like that, I could be wrong. You can put the trans in a forward gear first, you should hear a small clunk as the input shaft stops or partially release the clutch in a forward gear get it to stop, then go immediately to reverse.
If anything, I'd say your input shaft is still spinning with the clutch fully pushed in which may caused by a misadjusted clutch causing the input shaft to keep moving or your reverse idler or reverse gears are bad and not aligned or mating right.
Maybe someone that knows more about the T5 will speak up but I'd think you could narrow it down a little more by putting it in reverse once, back to N or a forward gear (without letting out the clutch) and then trying again to see if it was hard the second time. For the second time, the input sharf should definatley not be moving and it should not grind.
I've come to the conclusion after writing all of this that I have no idea and I've said a lot of nothing but damnit, I'm posting it anyway.
Old August 15th, 2007, 03:45 PM   #3
so everything you jsut said you have no idea what you were talking about...lol..ill try the cluth cable..but thanks
Old August 15th, 2007, 11:21 PM   #4
83 5.0's Avatar
83 5.0 is on a distinguished road
I just shift into 5th then put it into reverse, no problem. Stops the gears from spinning. Could never eliminate it with any amount of clutch adjustment. Just something the T5 likes to do.
Old August 16th, 2007, 05:51 PM   #5
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
No hold the clutch in and put it in 4th then reverse thats the trick mine did the same thing and it wont grind. Most almost all t-5s do that.
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old August 17th, 2007, 04:31 PM   #6
alright thanks..i guess its not a big deal then
Old August 17th, 2007, 05:24 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Bingo!
Old August 17th, 2007, 08:16 PM   #8
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
if you put it in any gear then reverse it wont grind
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Threads Similar to: t-5 problem
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
Has your car ever had a problem? JASonic The Clubhouse 17 September 19th, 2007 06:19 PM
big problem need help 96gtponyred 96-98 12 August 22nd, 2007 02:36 AM
RIM Problem and Help trueballerisme 2005 - 2010 70 August 21st, 2007 09:55 PM
TPS Problem? 88Horseman 5.0 Mustangs 11 November 14th, 2006 12:46 AM
