SERIOUSLY witch throttle body to get
Old August 15th, 2007, 09:59 PM   #1
gordon norris is on a distinguished road
i just dont know what to get my stock throttle body keeps sticking i have a stock intake but i dont want to just put a stock throttle body back on i found one on summit for 139 and the egr spacer for 49 should i get this or just get a stock one and wait until i get my intake
Old August 15th, 2007, 10:01 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
you should save up and buy an Accufab.
did you try cleaning the TB?
Old August 16th, 2007, 12:02 AM   #3
yeah i have cleaned it lubed it it just has a sticking point when its closed u have to jam on the pedal to get it open again
Old August 16th, 2007, 12:05 AM   #4
HMUSN's Avatar
iTrader: 9 reviews
ah.
well your 5.0 buddies will be able to help you more than I will man.
they will reply shortly with your answers...
good luck
Old August 16th, 2007, 12:08 AM   #5
1987 ford mustang gt
well see when shes done
Accufab bbk and holley are the best I would get a tb to match the intake port size
347, torn apart again.
Old August 16th, 2007, 12:37 AM   #6
well i am a dumb ass and i dont know what i need i have a stock intake so if i went with a 70mm throttle body what elase would i need my car is completely stock it has headman shorty headers on it with flows only would i need to change my intake manifold or my air intake
Old August 16th, 2007, 01:33 AM   #7
ultmtstang01 is on a distinguished road
you'll need a 70mm maf or bigger, assuming you have mass air. Also, it will need to be calibrated to your injectors, 19 lbs if stock. Port your intake to match the egr spacer. Stuf a rag in the intake, mark it by using the spacer, port it with a dremel, vacuum it out and then remove the rag. I think a 65mm t.b. will be fine though if you are stock.
Old August 16th, 2007, 04:57 AM   #8
i wouldnt go bigger than a 65mm TB on your motor...
If you want to go bigger, do it all at once..Top end kit, MAF, injectors, etc.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old August 16th, 2007, 07:57 AM   #9
sivart is on a distinguished road
is a egr spacer necessary?
I just read an article about the dangers of drinking ...
And it scared the crap out of me.
So that's it...............
After today, NO MORE READING.
Old August 16th, 2007, 10:41 AM   #10
yes i live in ca and i want it to pass smog i know they say 65 is max but i would hate to put on a 65 and wish i had just done the 70
Old August 16th, 2007, 11:05 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Did you adjust the stop screw on the throttle body. Throttle bodies stick when the throttle closes too far. I'd bet that is the problem with yours. Otherwise find another stock throttle body. Buying an aftermarket throttle body for your combination will be a waste of money.
Old August 16th, 2007, 11:19 AM   #12
i dont need smog where i live so do i need it still?
i think on my tb its no all the way closed when the engine is off.
Old August 16th, 2007, 02:11 PM   #13
DanishStallion is on a distinguished road
Witch throttle body broom stick
www.irmfclub.com
Old August 16th, 2007, 09:04 PM   #14
Red87DropTop's Avatar
Red87DropTop is on a distinguished road
If you are dead set for a bigger one a 65mm will do you plenty, but like Darrell said with a mild combo you will not notice anything. A stock intake will accept a 65mm TB without any mods, yes you need to match it with the same size spacer. You can hog your intake out to accept a 70mm but the stock intake will limit the flow potential of the TB. Anything over 65mm you really need some serious mods to back it up, blower, race heads, big cam. The only reason I upgraded mine was I got it cheap and I knew I was doing some more upgrades later. Hope this helped.
Old August 17th, 2007, 01:06 AM   #15
well u hit the nail on the head i just wasn't sure how far in i could turn that screw OK then one more ? does the throttle body have coolant running threw it i keep smelling coolant but cant find a leak but when i took the throttle body off it smelled like coolant and it was a brown cream like stuff and when i looked inside my intake i saw oil where would that come from and is this normal
Old August 17th, 2007, 01:15 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Take the throttle body off and determine what is causing the sticking. If it is the throttle plate, turn the screw until the plate doesn't stick. No coolant runs thru the throttle body but coolant does run thru the EGR spacer.
Threads Similar to: SERIOUSLY witch throttle body to get
CAI and Throttle body mrnewall 99-04 22 May 10th, 2007 06:13 PM
Throttle body shurb125 5.0 Mustangs 5 April 7th, 2007 07:03 PM
new throttle body? AFtriathlete General Tech 18 March 20th, 2007 01:14 AM
Throttle Body BlueStangV04 V6 Mustangs 26 September 20th, 2006 07:11 PM
