throttle body
Old July 17th, 2006, 10:09 PM   #1
ponymaneman is on a distinguished road
throttle body
ok i have a 92 mustang 5 liter of course..running no smog pump.Im looking into a bbk throttle body.Do i have to run a egr spacer?I dont think i have to but i would like to make sure.so if anyone knows id appreciate it the help.
Old July 17th, 2006, 10:10 PM   #2
Do I have to have a egr spacer on my 92 5.0 if i run a bigger throttle body?I have no smog pump?
Old July 17th, 2006, 11:46 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes you will need a matching EGR spacer. Is the car stock? If you are running a fairly mild set up a throttle body will be a waste of money. You'd be better off sticking that money into a set of gears or exhaust.
Old July 18th, 2006, 12:38 PM   #4
cobralini is on a distinguished road
So Darrell what you are saying is to wake up a stock 5.0 a set of 3.73's, a K&N filter, and a high flow catted h-pipe would do the trick.
What about adding an accel coil, 9 mm plug wires to the mix?
Old July 18th, 2006, 12:43 PM   #5
Sidewayz6.0's Avatar
Sidewayz6.0 is on a distinguished road
A new throttle body isn't always a bad idea. The stock ones are pretty small. It won't net you much at first, but you'll need one as you mod anyway. BBK makes a nice 70 or 75mm that come with the TPS and are pretty inexpensive. You do have to run the EGR spacer, only because the throttle cable bracket bolts to it. If you get a new throttle body, make sure you pick up a larger EGR spacer, or you're just pissing in the wind.
Old July 18th, 2006, 01:34 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes.
I wouldn't mess with the stock ignition at this point. The stock TFI ignitions work great. A set of Accel 300+ or MSD wires would be a nice addition. Stay away from Ford Racing wires.
Old July 18th, 2006, 04:13 PM   #7
Thanks !! cause a I was just about to get a fresh set of Ford Racing Wires.
I am comparing the ride to my old 94 GT (5.0) . In stock form it ran so much tighter and seem to breathe so much better. Then again we are talking about a 7 year difference.
Old July 20th, 2006, 08:20 AM   #8
mikes93fox is on a distinguished road
Darrell, why stay away from the FRPP racing wires? Just curious, I have never had any problems. As far as EGR, the only way I know you can get away from them is go to a Cobra intake. Then the Egr is built into the intake w/o the water jacket.
93 vert - stock bottom end, AFR 165's, Crane 1.7 RR, F-cam, Ported Cobra upper and lower, BBK 65 mm TB, Pro-M 76mm MAF, FRPP 24lbs inj, Novi 1000, BulletProof AOD, Alum. rad, MSD 6a, Blaster 2 coil, FRPP 9mm wires, Holley 255 FP, 3:73, and Cobra R's
Old July 21st, 2006, 11:05 AM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have yet to see a set of Ford Racing wires that doesn't arc all over the place. I put two new sets on one of my cars a few years back. Both sets were junk. I shoved them both up the Ford dealers ass. Many times I have fixed cars for people that just installed Ford Racing wires and the car started running like shit.
Old July 30th, 2006, 01:58 AM   #10
Guess I'll be replacing the plug wires
Old July 30th, 2006, 02:01 AM   #11
And back to the original question, one of the mods that I definitely felt a difference in was the Headers combined with the exhaust. If your going to stay N/A, I'd get a set of equal length headers. But if you plan on boosting in the future just by some shortys. The exhaust work is a mod that is well worth the money. Quit choking that car and let it breathe!
Threads Similar to: throttle body
Throttle Body Snipe061 V6 Mustangs 8 September 11th, 2007 03:28 PM
Throttle Body autoranch 96-98 4 August 7th, 2007 08:24 PM
bbk throttle body dumps 2005 - 2010 4 March 26th, 2007 07:02 PM
new throttle body? AFtriathlete General Tech 18 March 20th, 2007 12:14 AM
throttle body noppe180 96-98 2 November 4th, 2006 05:57 AM
