timing cover gasket
i got an 89gt and ive got a water leak and its leaking from the timing cover gasket.. how is tht possible?
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
It may be the water pump itself, they have a small hole in the bottom of the neck that water will drip from and eventually pour out of when the shaft seal goes bad. This water may be running onto the timing cover. If that is the source, I'd suggest a new water pump now before it starts pouring out and you run dry. I'm sure each pump failure is different but I went about 200 miles from the drip to full stream.
what is the water pump seal. the leak sits between the block and the timing cover... not the water pump and timing cover
The water pump seal is internal to the water pump used to seal around the pump shaft. When the seal goes bad, water will drip out of a small hole in the neck of the water pump. This water can run on to the pump and on to the engine or be blown all over the front of the engine from the fan. Sounds like your leak is somewhere else.
Time cover gaskets go bad I just changed one on my 302 in my Bronco and My 89 mustang had one go bad a few years back. PITA to change too. Have to remove the front of the motor. Good time to pit on a new timing chain tho.
Threads Similar to: timing cover gasket
| BBK Valve Cover Gasket | Hotrodvdog | 99-04 | 20 | December 24th, 2007 06:09 PM |
| changed valve cover gasket | caintcatchmyGT | 96-98 | 1 | November 4th, 2007 02:32 PM |
| Timing cover gasket, need help fast | 99v6stang | V6 Mustangs | 1 | August 6th, 2007 08:08 PM |
| valve cover gasket | terribleonexx88 | 5.0 Mustangs | 5 | July 25th, 2007 04:20 PM |
| Need instruction on gasket on the timing cover | OTreborO | General Tech | 1 | June 19th, 2006 03:01 PM |
