Stupid question but need to ask
Ok I feel like a retard for asking this but I need to know. Does a 95 5 speed tranny have its own fluid or is it shared with the engine oil. I cant find the dip stick for the tranny.
'95 Blk GT....Complete Magnaflow exhuast with o/r H-pipe...CAI...PVC system by-pass...25%Underdrive...9mmFRPP wires...Smog pump delete...Battery relocate...Intrax 3inch lower...Hurst shifter...3.73's...Interior renos |
you prob won't. if it is a standard tranny there isn't one. if it is a T-5 there are two plugs on the passenger side. the upper being the fill and inspection plug and the lower being the drain. they can be removed with a 3/8's ratchet. and if it is a T-5 it holds 3qts. of ATF dexron III.
The only stupid question is a question not asked. Its better to ask a question and get the right information than it is to not know and wreck something. So don't feel bad for asking. There is no dipstick on a manual transmission. There are 2 plugs in the driver side of the transmission. The lower plug is a drain plug and the upper plug is the fill/sight plug. The fluid should be at the bottom of the plug hole on the upper plug.
Koo thanks for that...I guess it's time for a tranny fluid change...probaby hasnt been done in awhile...lol.
a t-5 uses automatic transmission fluid? i thought t-5s were 5 speeds wouldnt that use gear oil of some weight and viscosiity?
iwinz wagownd i <3 my 289 |
Yes it is a t-5. Will any automatic fluid work? any recommendations on quality fluid?
#7 | |
#8 | |
#9 | |
mine were, they were located in the main tranny housing, i found the easyest way to fill it. was to remove the shifter basle and run a piece of fuel line through the floorboard down into the tranny. and hook the hose up to a bottle and squeez it in from the cab.
1988 lx t-top
mine are on the driverside but mine is the world class t-5
1999 Ford Mustang V6
yeah you can fill through the shifter boot opening unlike the 05+ stangs, which is a great time to swap out the shifter if you can afford it! sometimes when in a time pinch i use a gear oil bottle, clean ofcourse, with some tubing on the end to pressure fill it from under the vehicle, there is some leftover but saves time.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Threads Similar to: Stupid question but need to ask
| probably stupid question | dgt_mustang | V6 Mustangs | 7 | November 9th, 2007 12:54 PM |
| maybe a stupid question maybe not? | KhaosGT | 99-04 | 3 | October 16th, 2007 12:30 PM |
| Stupid Question | MustangMatt96GT | Modular Mustangs | 76 | May 6th, 2007 09:47 PM |
| Stupid Question | barksdaleammo | 99-04 | 21 | March 31st, 2007 10:54 AM |
| Probably A Really Stupid Question | Joey304 | Classic Mustangs | 16 | November 1st, 2006 07:21 AM |
