---Have 5 grand want 400hp---
Old August 18th, 2007, 05:34 PM   #1
WTFJayJay is on a distinguished road
I want to get my 94 gt up to 400hp and ive got 5 grand to work with. Im thinking about a Vortech supercharger, then that leaves me with 2 grand, so what else should i do for power mods?
Old August 18th, 2007, 05:37 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
Turbo kit you will get more bang for your buck
Old August 18th, 2007, 05:55 PM   #3
1987 ford mustang gt
well see when shes done
Turbos are very expensive,I would do heads,cam,intake and all the other little stuff and put a 100 shot on it.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old August 18th, 2007, 06:06 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I agree. $5000 would get a nice turbo kit and still have money left over to buy a set of nice used aluminum heads.
Old August 18th, 2007, 06:09 PM   #5
well im pretty sure im going with the vortech kit now, so what heads and cam should i get to go with it?
Old August 18th, 2007, 06:23 PM   #6
TurboLX's Avatar
Dude you would be more happier with a turbo kit, best 4k you'll ever spend,
Old August 18th, 2007, 06:33 PM   #7
will the turbo give me as much power as the vortech kit with new head and cam?
and where can you get a turbo for 4000? the only ones ive found are the cheap ebay kits, or they are 5000+
Old August 18th, 2007, 06:42 PM   #8
1965 Mustang Fastback
nba1341 will become famous soon enough
it will give you more power and are you looking at TT or turbo?
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old August 18th, 2007, 06:45 PM   #9
so the turbo will give me more?
this is the only one i can find for 4grand.. http://www.cruizinconcepts.com/detai...ct_id=PTK-SNS5
Old August 18th, 2007, 06:45 PM   #10
TurboLX's Avatar
See with a turbo, you adjust the boost (PSI) Per sqaure inch
You can adjust the PSI on a turbo giving more or less HP just by turning the boost controller, where as a supercharger is limited and uses HP to make HP
Read my write up in the general tech section, under power adders, the sticky at the top, Lets talk boost, read as much as you can
you can pick up a nice HP performance turbo kit for $4500 and is good to 500hp, Stage 1 kit which is all you need
www.Hpperfromance.com
Old August 18th, 2007, 06:59 PM   #11
wow great write up! the helped me out alot! thanks!
Old August 18th, 2007, 07:15 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+9999999999999999999999999999999999999999
Old August 18th, 2007, 07:16 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Turbos produce more horsepower than any other power adder. They are more efficient than a supercharger and less stressful to the engine.
Old August 18th, 2007, 09:39 PM   #14
www.quicktimeturbosystems.com
$2900 for a 70mm single turbo kit, plus shipping, and you still have money left over! This kit can produce enough power to split your block if you unleash it!
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old August 18th, 2007, 10:46 PM   #15
TurboLX's Avatar
Newt-Rod has quite the long waiting list
Old August 19th, 2007, 06:16 AM   #16
sivart is on a distinguished road
i thought NOS was the cheapest poweradder, but a turbo will give you the HP u'll be looking for. + u get that cool blow-off sound and run it open wastegate
I just read an article about the dangers of drinking ...
And it scared the crap out of me.
So that's it...............
After today, NO MORE READING.
Old August 19th, 2007, 06:38 AM   #17
NOS doesnt give you constant power
I'm a good boy now.
Old August 19th, 2007, 07:20 AM   #18
it will if you have alot of it
Old August 19th, 2007, 10:21 AM   #19
92Rideagain is on a distinguished road
You cannot go wrong with a Turbo kit. They are easier today than they were 15-20 years ago. They are out of the box bolt on rather than the costly fabrication that had to be done to make them fit properly. I have read an article in MMFF recently stating that they have now fitted a turbo waste gate to a super charge application. It allows the driver more control over the boost levels which evens the playing field a little more between the 2 power adders. A properly tuned turbo setup will give more bang for your buck.
Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety.
"Benjamin Franklin"
Old August 19th, 2007, 11:01 AM   #20
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
dude
stay with natural aspiration
Cam, intake, new heads, bore and stroke it, new lifters and rockers.
you can get 400 hp without going the forced induction route
http://www.carcraft.com/techarticles...dup/index.html[/url]
Threads Similar to: ---Have 5 grand want 400hp---
grand prix vid Santaniello3blkstang The Clubhouse 20 June 24th, 2007 06:16 PM
new m3 v8 powered...400hp+ jat 2005 - 2010 7 April 21st, 2007 11:11 AM
Mustang V6 vs. Grand Am Countryboy_99 Racer's Corner 21 March 27th, 2007 11:30 AM
97 grand am Bies08 All Other Vehicles 4 March 14th, 2007 08:44 PM
