1987 Mustang GT
surging idle help
I have a problem with my 87 mustang gt's idle it surges by about 400 rpms and them dies. I have tried just about everything from running codes to resetting base idle numerous times. Just curious if any of you guys have any ideas. I was told that idle issues can be worked out with a tune via a chip or pms type device is this true? Thanks for any help you guys can provide
IDLE ISSUES
Hey
I Had The Same Issue With My 94 Gt I Cleaned The IAC (IDLE AIR CONTROL) And Clean The MAF That Stopped My Car From Dying Out Sumtimes It Can Be A Fuel Pressure Regulator U Can Hook Up A Guage And See If The Fuel Pressure Is Correct I Would Clean The IAC and MAF Hope This Helps PaT #06 |
1987 Mustang GT
surging idle help
Ive actually replaced the mass air meter and the iac. I just got done spraying the vacume lines with card clean and the idle doesnt change so im beginning to rule out a vaccume leak. The only thing i can think of is a kink in the return line on the fuel tank when i swapped to the 255lph fuel pump. Is it possible to have a surging idle from that??
i doubt it...
yea i dont think that would be a problem
i would check just in case tho wow im stumped ill ask around and see what else i can find PaT #06 |
1987 Mustang GT
surging idle help
yeah the only reason i think the fuel line is because it was kinda in bad shape and after putting the pump in i find that i cant back the fuel pressure down with my adj regulator as low as i used to before the install, ive actually backed the screw almost out of the regulator and it still wont come down. idling my wideband stays around 10.0 and the fumes will drive you out of the garage.
sounds like you have a bad ECT or ACT to me.... might wanna check those out
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
try disconnecting and cleaning the "salt and pepper shakers" and by that i mean the two big wiring connectors on the top/backside of your plenum.
Threads Similar to: surging idle help
| Compressor surging. Need new bypass.... | Stangtuner | General Tech | 12 | January 13th, 2008 05:40 AM |
| engine surging | chickenbot | 5.0 Mustangs | 13 | November 13th, 2007 01:31 AM |
| Surging 5.0....Please help | REBELPONY | 5.0 Mustangs | 28 | August 30th, 2007 02:53 PM |
| gt surging when in gear with brake on or ac on | dobermean | 99-04 | 1 | August 20th, 2007 10:18 PM |
| Engine Surging @ Idle | Milner62 | General Tech | 0 | August 22nd, 2006 02:56 PM |
