Discussing Aftermarket intake vs Cobra intake... in the 5.0 Mustangs Forum. Hi, I have a 95 cobra w/ the stock intake manifold, and I was wondering ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Aftermarket intake vs Cobra intake...Thanks, Brent |
i would leave it alone ,your really not gonna gain much,especially if the motor is stock.the cobra intake may be dated but its a great intake.if you do take it off hang on to it the origanal non repro's are hard to find.
93 GT Hatch
12.68@112.57
yea they are pretty good, the only thing i would do is maybe port it. but keep it on.
http://www.geocities.com/vz_one/superman5.jpg |
+1 The Cobra is a great intake for your stock motor. I would only change if the motor was stroked or you had a power adder.
Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety. "Benjamin Franklin" |
Thanks for the responses guys. I think I'll just leave the Cobra intake on.
1995 Cobra -BBK LT headers, BBK o/r x-pipe, Flowmaster 40 series -BBK CAI -BBK 70 mm TB -ASP UD pullies -Smog pump eliminator -MSD ignition -Steeda Tri-Ax shifter -Eibach Pro-kit springs -BBK subframe connectors |
if you should ever decide to swap out the intake. Consider a Holley Systemax2.
try to avoid the professional products typhoon intake.
88 Gt
not slow
+1,... like everyone said,. your cobra will do fine with little to no mods,..but like adder said,when swapping look into holley's stuff,.. systemax's are the highest flowing intake
1993 Lx
14.097/98.2
go aftermarket if you go over 350hp, thats what ive heard them rated at, but then of course you could get it ported
Foxbodys FTMFW yay no more centered threads!!!!!!! |
1987 Mustang GT
there is nothing wrong with the typhoon intake other than having some rough casting in the runners but that can be smoothed in no time.
since your long block is stock, I venture to say an intake swap would net less HP. The stock Cobra can be ported to flow 250-260cfm for heads that flow in that range if decide to upgrade heads later.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer P heads drilled for smog, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.tmossporting.com |
1989 Mustang GT
how much hp did 94 and 95 5.0s create
11.95@113MPH
Cobra intakes work great. If you get a Trickflow/Eddy intake, get some heads and a cam as well...otherwise, no differance!
2002 Mustang GT 4.10's, NX 100 shot, MGW shifter, ET Streets 60ft: 1.63 1/8 ET: 7.60@90MPH 1/4 ET: 11.95@113MPH 1986 Mustang GT 4.10's, NX 150 shot, TKO, "P" heads, etc... 1.93 60ft 8.33@84MPH (stock w/100 shot) |
Threads Similar to: Aftermarket intake vs Cobra intake...
| cobra intake | fastlane_24 | 94-95 | 5 | June 12th, 2007 10:04 PM |
| Aftermarket Intake Manifold | Garman91 | V6 Mustangs | 18 | April 5th, 2007 03:05 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
| Intake for a 97 cobra | DRAD14 | 96-98 | 6 | March 26th, 2007 10:55 PM |
| Cobra cold air intake.... | True2theHorse | 96-98 | 3 | March 17th, 2007 12:22 AM |
