heads
hey there folks i'm new to this forums and i was wishing to hear some opions. I am wanting to purchase a new set of heads to start the process of a top end build. i was wondering what a decent head to purchase was. I pretty much have it narrowed down to 4 heads.
thumper full port,hi rev springs milled .40 edelbrock vitor jr's. trick flow twisted wedge afr 185's..how true is it about piston notching? i would like to run a cam that would allow me to keep my aod shifting at the same range which is 5k with a nice lope. i have some light mods here they are. hooker headers full exhaust w/ cats 2.5 inch 14* timing bump front sway bar removed aod w/ shift kit shifts at 5k 4:10 gears thanks in advance for the help. btw my build will look like this completed heads ( need help there ) trick flow track heat intake 75 mm upper intake spacer 3/4 inch 70mm throttle body with spacer 76mm mass conversion afm power pipe 3000 stall converter 1.6 rockerstrick trick flow timing chain and gears tfs pushrods i was looking at 3 cams: anderson fords n-51 cam, trick flow stage 2 or a having a custom grind per application but unsure where to go and the average cost. again any help would be great. |
thats an awful lot of questions have you used the search button on the top of the page, there is alot of discussions on all of these
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
yes, i will search again though thanks.
AFR Heads
i HAVE A 351 WINDSOR AND I HAVE AFR'S 185CC 61CC THAT ARE REALLY PRODUCTIVE AND ARE STRONG ENOUGH FOR 302-392 ENGINES THE PISTONS SHOULD HAVE ANY PROBLEM WITH THESE HEADS I STRONGLY RECOMEND THEM.
1987 ford mustang gt
well see when shes done
You can not use afr 185s on a 302 with stock pistons they will have to be flycut!They have a 2.02 valve and stock pistons can only hold a 1.94.
#6 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
I think trick flows are good and they have a nice stage 2 cam that should work w/o cutting the pistons. But if you are wanting high compression you should see how much room you are working with.
I think (not sure though) trick flow tw wedge heads are the only aftermarket heads with a 2.02 valve that will work with stock pistons.But afrs will not work unless they are the 165s.
unless you are stroking or supercharging or turbocharging the motor then yu would not need the afr 185s. get the 165s.
They are way to big of a head for a 302 if theres no poweradders or stroking going on.
Threads Similar to: heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 10:01 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| 289 Heads | ezra27 | General Tech | 0 | December 31st, 2006 12:09 AM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 04:18 PM |
