Discussing SMog pump delete kit in the 5.0 Mustangs Forum. I bought my kit off of summit and it didint come with any bolts should ...
Old August 19th, 2007, 09:49 PM   #1
I bought my kit off of summit and it didint come with any bolts should my old ones fit?
Old August 19th, 2007, 10:09 PM   #2
dr.gonzo's Avatar
I just bought a shorter belt and rotated my belt tensioner. No need for another pulley
FREE LUNCH, FINAL
WISDOM, TOTAL COVERAGE... WHY NOT?
Old August 19th, 2007, 11:02 PM   #3
jam77's Avatar
1987 Mustang GT
the origanal bolts fit on mine
Old August 20th, 2007, 12:54 PM   #4
you dont need a dlete kit... just get a shorter belt.
Old August 20th, 2007, 12:55 PM   #5
Timm10221's Avatar
Location: Stationed in Jacksonville, NC ; Home Town PSL FL
yea i ripped mine off then routed the belt accordingly
Military Crew USMC CPL
1995 Mustang GT
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Old August 20th, 2007, 01:28 PM   #6
what size belts did you go with?? i do not have A/C.. and what is it you are doing with the tensioner??
Old August 20th, 2007, 01:46 PM   #7
the SN-95 and the fox use different length belts. I ran a 805k6 for my car, but I believe the fox uses a 795k6
Old August 20th, 2007, 02:04 PM   #8
dr.gonzo's Avatar
I rotated it counter clockwise a little bit because the tensioner would of pushed down too and rubbed the belt together. I think you will need a ac delete kit as they dont make a belt that short (that I know of.)
Now looking At mine I routed it weird. It still spins the same way. I dont know what size belt I had all I know is I made it work. lol an some how the alternator doesnt budge.
FREE LUNCH, FINAL
Old August 20th, 2007, 02:21 PM   #9
most people run the belt in the manner the diagram shows b/c they have had clearance issues with the tensioner pulley and water pump pulley
Old August 20th, 2007, 02:24 PM   #10
dr.gonzo's Avatar
I didnt find this site before I attempted this lol
FREE LUNCH, FINAL
Threads Similar to: SMog pump delete kit
Smog Pump Delete? 5-0stank 5.0 Mustangs 20 July 14th, 2008 04:24 PM
smog pump delete bigwhiskey 5.0 Mustangs 4 June 30th, 2007 11:02 PM
How To Delete Smog Pump On 95 GT the95..5-0 5.0 Mustangs 2 September 13th, 2006 12:43 AM
Smog Pump Delete mdvaldosta 5.0 Mustangs 2 September 11th, 2006 11:13 AM
Smog Pump Delete? 00SoSlow V6 Mustangs 18 August 16th, 2006 12:04 AM
