13.64@101mph
Got Her Running, But wont stay running...help?
hey guys..installed the cam and other valvetrain stuff..and after bout 2 days of messing with the timing, it turns out that i just had the firing order ontop of the distributor wrong...well i finally go it started this morning, and she revs real high to start and then wont idle, just dies out..im not so great w/ this EFI stuff so i may have missed something..i do know one thing is that i dont have a vaccum line going to the fuel pressure regulator..just cant fined the missing line or what going to that..i also have 2 vaccum lines that going under the backside of the upper intake? dont know if those lines are to the right spot..(should have marked them at tear down) and also on the front underside of the upper intake is 2 spots for more vaccum lines..i dont have any extras laying around..please tell me what im missing and what goes where...thanks alot to ALL responses...
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
It sounds like you have a HUGE vac leak which is causing issues with your fuel metering. Stop at a store, like autozone or advance autoparts and buy a couple vaccum tree plugs. Cover up any unused vac ports, and if you have to, insert a T into one of your vac lines, then run it to your FPR
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
13.64@101mph
well i have 2 unused vaccum ports open under neath front side of upper intake.. the to on the back..one goes to the FPR? and the other to the MAP? but what and where is the MAP? and then i have this thing that has 4 vaccum lines coming out of it..one goes on smog pump hose..and where do the rest go????
you shouldnt have any vac lines attached to the BAP sensor (what your calling a map sensor)
and none of those ports should be open.. at all.. plug them
13.64@101mph
well im going with a website that had diagrams of the vaccum lines location..said something bout a MAP..well im gunna just go by all new vaccum lines..that way i'll have all im missing and with be label w/ were from and were to..best bet..or just plug all open stuff and connect FPR to Upper intake vaccum port..
you dont need to follow a stock diagram... just plug up all the ports, and run a vac line from the intake to the FPR
i know a few cars that i have messed with, if you adjust the screw on the bottom of your throttle body, you can make it idle higher...probably not the answer you are looking for but with a cam it might be the only solution...not to discredit the vacuum issue either, because that can cause a problem as well
#8 | |
13.64@101mph
yeah, definately don't run a vacuum line to the MAP. that really screwed up my air fuel mixture when mine was connected
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
#10 | |
13.64@101mph
95 5.0L COBRA
95 COBRA
Not All Who Wander Are Lost. ![]()
Threads Similar to: Got Her Running, But wont stay running...help?
| 88 5.0 sometimes starts but won't stay running | cylance | 5.0 Mustangs | 8 | August 28th, 2011 06:59 PM |
| wont stay charged | itsmyfiveoh | 5.0 Mustangs | 1 | June 22nd, 2007 04:26 AM |
| Got the car together and Running | 86er | Drag | 3 | April 16th, 2007 11:39 PM |
| pile wont stop running hot! | j2000_guy | 5.0 Mustangs | 10 | April 5th, 2007 11:00 PM |
| Stang wont stay running, after warm up...???? | ttop5.0 | 5.0 Mustangs | 2 | November 28th, 2006 05:10 PM |
