Idle question
Old August 21st, 2007, 02:12 AM   #1
dadstoys2 is on a distinguished road
Idle question
Ok I know that its not a mustang but I cant seem to find anywhere on thunderbird board to get much for answers. My Thunderbird is at least the HO 5.0 so here goes the questions. Hope you guys can help.
We have recently had a problem with our 92 Ford Thunderbird 5.0 V-8. On my wife’s way home the car began idling between 2300 – 2800. She got the car home, and my first thoughts were a vacuum leak. I used a can of carb cleaner and sprayed liberally all over vacuum lines, intake and the manifold, throttle body etc. I found nothing. I noticed that the exhaust manifolds were turning cherry red with in 3 – 5 min’s. Which again could be due to a lean situation due to un-metered air . Since I found no vacuum leak, I am beginning to think that maybe the timing had jumped. My next question is checking timing. Where is the spout in connector? How many wires, and where does it go....both directions....does it go to the distributor? If anyone has any suggestions please help me out with this.
Thanks,
~Rich
Old August 21st, 2007, 03:55 PM   #2
Well I did find the plug. but since the idle is so high I cant set anything. I did put the light on it and it looks like its about 15deg. But with the idle up I cant go by that.
Does anybody have any ideas? I have disconcted the battery to clear code and hope that I can find a way to check it for any new codes. Does anyone know how to check the codes?
Thanks,
~Rich
Old August 21st, 2007, 07:32 PM   #3
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
some one help him cuz i need to check codes too
Old August 23rd, 2007, 03:41 AM   #4
http://www.muscularmustangs.com/test1.php
Here it says how to check the code on the mustangs, which should be the same for mine. Not very easy to follow though.
I am looking into the IAC tomorrow just not sure if that would explain for the cherry red manifolds.
~Rich
Old August 23rd, 2007, 04:04 PM   #5
1993 5.0 notchback
91 5.0 lx hatch is on a distinguished road
i dunno bout the thunderbird but usmc to check codes its up by your brake fluid thingy lol
Old August 24th, 2007, 05:57 AM   #6
Turned out it was the IAC. Changed it and car runs great again.
~Rich
Old August 24th, 2007, 12:13 PM   #7
IcantDo55 is on a distinguished road
~Rich
Unless you changes the motor the T-Bird came with the non-HO motor.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old August 24th, 2007, 02:15 PM   #8
Nope...This is the HO 5.0 and its factory.
Threads Similar to: Idle question
small question about dropping idle flattusmaximus78 V6 Mustangs 4 July 15th, 2007 09:48 PM
idle question 00vabchgt 99-04 7 May 10th, 2007 03:03 PM
Idle question? dmachine22 99-04 4 April 15th, 2007 12:12 AM
Newbie Question - Hanging Idle unitl stop Murago 5.0 Mustangs 10 August 2nd, 2006 12:17 PM
94 GT idle question... WVSNS& 5.0 Mustangs 1 February 10th, 2006 04:12 PM
