Discussing carburator in the 5.0 Mustangs Forum. ok i have an 89 gt and i am switching from fuel injection to carb... ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
94 Mustang GT
carburator
ok i have an 89 gt and i am switching from fuel injection to carb... i was wondering if there is an adaptor to hook to the fuel line to were it would connect to carb. i have a holley four barrel.
they sell braided lines that connect from the lines to the carb..you can usually get them at autozone or napa
http://i34.photobucket.com/albums/d1...themsutang.jpg |
first off you dont want to use the same fuel lines or the same fuel pump and your gonna be hooking it all to a regulator first then you will have 2 lines run from your regulator to your carb
Mostly correct, Mallory is the only company that I am aware of that sells a high pressure to low pressure return style regulator designed for converting an EFI fuel system to a carb. Summit sells them. With this regulator you can use the same lines and pump all the way up to the inner frame rail in the engine bay. There you would mount the regulator, hook it up to the stock steel lines using a flare tool and some hose clamps. Then you can use braided hose for the rest of the set up. Most stock style carb setups use 3/8" hose barbs.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
1983 Mustang GT
N/A
What else do you need to go from EFI to Carb? I know the intake and carb and the above mentioned, but is that it?
Your cars look likes a skinny hard onn
with a big bell end.
1990 LX hatch
HKS has both a vagina and balls, but no penis, he can be seen on youtube under the clips called shemale stories.
#8 | |
You know so much! You sure its your car with its dodgy cylinders? Your car is a heavy fucker what carnt turn corners. Thats why there shit. Oh your mom is next to me. Shes giving me a blowjob.
1990 LX hatch
I carnt too turn corners, right to your dads house where we tag your mom and your dad tells me how he touches you.
#10 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#11 | |
1989 Mustang LX 5.0
12.86@ 111mph
![]() 1989 Mustang LX 5.0 Stock w/ F303 cam and 1.6 Roller Rockers BBK Shortys, BBK o/r H, Flowmaster Super 44s "The LS1 was subject to a paternity test!!! The results are back....03 cobra you are the Father!!!!" |
91 Sonic Blue Goodness
19.83 @ 12mph
^ that 5 year old will be banned by morning.
don't worry about it.. the mods already know. |
#13 | ||
94 Mustang GT
thanks guys that helps alot. and that all i have to do is hook up the fuel lines.
Yeah, you might want to make sure your pressure is set below 10 psi before hooking it up to the carb or you might damage the carb. Also, double and triple check your work for leaks. Fuel system leaks are a sure way to end up with a burnt pile of ash where your car used to be.
Also, if you have the extra money, Army Navy (AN) fittings are the way to go. You also might want to consider upgrading your whole fuel system if your power level is going to be much above 300 hp.
Threads Similar to: carburator
| carburator tuning!! | 78mach1 | 5.0 Mustangs | 22 | October 25th, 2007 04:47 PM |
| Fuel infection or carburator | jrfan4life | 99-04 | 9 | March 13th, 2007 05:32 PM |
| carburator question about secondaries | ridinbikes247 | Engine | 1 | January 14th, 2007 08:59 PM |
| EFI to Carburator Conversion $ | shockashark | 5.0 Mustangs | 2 | October 31st, 2006 08:48 AM |
| 305 Quadrajet Carburator | green machine | All Other Vehicles | 17 | September 11th, 2006 02:44 PM |
