Discussing running hot on a/c in the 5.0 Mustangs Forum. i have a 94 stang and when i turn on the a/c the car ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#1 | |
running hot on a/c
take your fan relay out.. put a jumper wire(a piece of safety wire will do) between the power and ground contacts where the relay plugs in. if your fan does not come on right away, its time for a new one. if it comes on then your relay will probably need replaced
thanks
thanks for the advice i'll go give it a try right now
the same thing was going on in 2 of my work trucks , it was the fan relay
Do not jumper across the "power" and "ground" contacts, you will blow something up. I am not familiar the wiring on a 94 so I can not reference specific wires but you will need to jumper across the contacts that supply power to the fan and those are not called the power and ground contacts. Think about that, power is a power source, ground is ground. If you put a jumper across those, you are putting the voltage source directly to ground through a wire. You need to find out exactly which two wires to jumper across before you do it.
1991 GT - Original owner, all stock 1988 GT - The project car |
you need more than likely a new pigtail harness... same problem with my friends we fixed last night... although could be something else but there is an option. good luck and let me know if you figure any other querks about it
#7 | |
#8 | ||
:lala
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
#9 | |||
2007 Explorer Sport Trac, 292 HP, Stock 2002 Mustang GT |
Me.. It wont hurt if he just jumps the wire 4 a sec to see if the fan works..
#11 | |
Maybe I was just being anal but I was trying to prevent someone from getting confused by the details.
Way back when, someone stated to bypass the relay, jumper across the positive and negative wire. I think they meant to say to jumper across the switched part of the relay which is NOT called the "positive and negative", if anything, it would be called the "line and load" lines or the "switched leads". That may seem like a small detail but I had visions of someone looking at some wiring diagrams or a test light, seeing a positive and negative and thinking that jumpering across + and - was how you bypassed and tested relays. Zilla, i was not questioning the concept of actually jumpering around the relay for testing, just the method given for how to do it. There is nothing wrong with bypassing a relay for testing. I know a lot people know how to bypass a relay but for those that have not done it, using + and - as stated would cause very bad results. Put a jumper across the + and - terminal of your battery and see Like I said though, I know the person did not really mean to say the + and - lines and I was trying to clear up potential confusion, in reality, I may have caused more.
Yeah you got it. I think we were all a bit confused a bit.. lol..
Threads Similar to: running hot on a/c
| RUNNING HOT!!!!!!! | BLACKNIGHT5.0 | 94-95 | 37 | September 5th, 2007 03:27 PM |
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 9 | August 21st, 2007 12:44 AM |
| not running right | jkovacs60 | General Tech | 2 | August 3rd, 2007 02:13 AM |
| Bad running... | alabamastanger | 5.0 Mustangs | 4 | July 15th, 2007 06:25 PM |
| Just Got Done Running a 89 LX 5.0 | Bigb2000GT | 99-04 | 1 | March 19th, 2007 06:57 PM |
