Estimated Horse Power Numbers?
Ok. Debating on a carb swap for my car. '87 5.0 factory forged flattops and new Moly rings, all new rods and mains and new cam bearings. all stock w/ LTs. what if i go with some slightly worked over gt40 irons, TFS st. 2 cam, edelbrock performer intake, and 600 Holley with LTs. 5 speed car. Where about would the RWHP be with that setup.
'87 Mustang 5.0 T5 Coupe New motor I/P: stock shortblock Edelbrock heads Typhoon Intake 70mm TB 80mm MAF 24lbers 1.7 rr B303 cam. Shooting for 300rwhp? |
1987 ford mustang gt
well see when shes done
Do you drive this car everyday.
With fresh GT40P heads and EFI it will make around 260 at the wheels. Carbureted would probably make the same ballpark horsepower but at a loss of torque. I have to ask, why do you want to run a carb?
#4 | |
1990 LX hatch
1987 Mustang GT
there seems to be alot of posts lately about going to a carb. why is that?
im actually thinking of selling my carbed 302 to go fuel injected..having a carb for the first time was def. a great learning experience though..for me it was a lot easier to work on a diagnos, plus i didnt like the fact of all the sensors and what not..but im pretty sure both have its advantages.
Threads Similar to: Estimated Horse Power Numbers?
| How Much Horse power do you have? | Nameless122 | V6 Mustangs | 136 | August 24th, 2007 05:21 PM |
| 4.6L 32V cobra horse power CAP. | Smoph | 99-04 | 7 | June 9th, 2007 02:45 PM |
| Mustang Horse power (2005 GT) | Exseque | Modular Mustangs | 9 | February 23rd, 2007 12:11 AM |
| Horse Power | FTHOODV6STANG | V6 Mustangs | 25 | October 15th, 2006 01:26 AM |
| Stock horse power info please | trebel14 | 5.0 Mustangs | 3 | July 25th, 2006 02:18 AM |
