iat sensor?
ok duh newbie question. does my 90lx with 5.0 have a iat and if so where the heck is the sucker? thanks take care.
not sure and it would be (if you have one) on your intake box
Number five lower intake runner?
any clue what it would look like im a convert from gm and those are directly in the air intake so with me being new to mustangs this is kickin my rear. ill look again at #5 intake runner. thanks
it would look like the same as the GM.s
It's on the lower intake... driver side, near the front.
1990 LX Notch, with the heart of a 93 GT vert' (R.I.P.) |
#7 | |
http://www.mikebert.com/public/pictu...erence/iat.jpg |
the small plug behind the first injector on the right hand side that is grey in color?? mike??
#9 | |
It should be plugged into the same harness that connects all the injectors. |
sweeeeeeeeeeeet found it thanks hmusn, blueoval and mike the pic helped a slow guy like me lol. thanks take care. damn its good to actually talk to people who know what they are doing and actually want to help. i didnt have this pleasure with all my GM "friends" lol
It's cool. I've got pictures of everything from the pistons up, so ask if you run in to more trouble.
ohhhh im sure i will run into more trouble LOL. new to mustangs, but im learning. mostly from on here. thanks
ok im back got a debate question. i found a site that says to fool the iat with a resistor to make the computer seem like the air charge is cooler/denser? it is saying to use a 100k ohm resistor, a friend had a 10k resistor and i tried it, and seems to me to be working, feels better revs quicker and is alot quicker during take offs. now first debate is would you even do this? why yes or no, second if you would, would you use the 100k ohm resistor. like the site says or stay with the 10k. yes i know this is cheesy but im looking for as much low buck but safe and worthwhile as i can get, untill i can afford the supercharger, lol. thanks for any and all imput. take care.
the site is rogueperformance.com, i hope i spelled that correctly
I have heard this argument before. I think its really tough to say. The IAT is there so that on hot days when the intake air is super hott the computer can pull timing to prevent detonation. Now if you go running your car on super hott days with a reisistor in there to trick to computer into thinking your air charge is 50 degrees cooler than it is you could possibly cause detonation. I am also sure the fuel tables are a bit different based on what your IAT temperature is so that could affect things as well. I would not personally do this because the amount your going to gain is so negligible its not even close to the risk for me. You might be different however. Anytime you start altering the car from its factory form there can always been drawbacks to it. Even if 1000 people post on here and say its fine and they have never had an issue you could be that one guy that has major issues and it costs you a motor somehow. You just never know for sure.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
well i tried it before i read this i gained 18hp at 3800 rpms, the tires will light up in hearbeat, runs faster sounds better and the seat of the pants feel is niceeeeeeeeeeee. i have the 10k ohm in there but im gonna try the 100k ohm resistor and see if is any difference. the one thing that i did see which could be an issue because i use 93 octane with a booster is i actually saw a drop on my gas needle where as before i was getting insane gas milage, maybe not everyones good gas milage because i am new to mustangs and used to big block chevys getting a good 3-5 mpg so anyyyyything is better but the mustang is muccch better even with all the mods. ill update this on the good or bad with the 100k. thanks for the info though. take care.
Threads Similar to: iat sensor?
| o2 sensor help | mustangrebuilder | 2005 - 2010 | 0 | June 25th, 2007 08:55 PM |
| o2 sensor | SPF0percent | V6 Mustangs | 6 | June 9th, 2007 01:08 AM |
| TPS Sensor | bigbadtalontsi | 5.0 Mustangs | 0 | March 27th, 2007 09:47 PM |
| MAP sensor | ROBBED666 | 2005 - 2010 | 0 | October 9th, 2006 04:12 PM |
| MAF sensor | 5.0 Rono | 5.0 Mustangs | 2 | July 16th, 2006 09:51 PM |
