Blue box behind a/c controls?
What is the blue box that sits behind the a/c controls? How do you unhook it from the dash to move it? I was going to install my radio in the top and move the a/c controls down and saw the box which would prevent the radio from going into the dash. Thanks.
-Mike |
that blue box is for the Air Bag. If you try to move it or unplug it, just disconnect the battery just in case you set the airbags.
#3 | |
If I recall correctly it has 2 metal flat tabs in the bottom. I dont recall if a flat screwdriver was used to remove it or if i just pulled it. Sorry I cant recall, hopefully someone do and can answer.
#5 | |
#6 | |
I unbolted the box and can move it around now. Does it need to be hard mounted or can it be pushed back and have some free movement? Does it need to be flat or can it be installed at an angle? Thanks. -Mike |
if its for the airbag i would def. hard mount it somewhere cuz if youre in a crash it might not depoly if its just floppin around in there
Threads Similar to: Blue box behind a/c controls?
| WHAT IN THE BLUE F-- | TheUNZippee! | The Clubhouse | 8 | September 26th, 2007 11:38 AM |
| Heat Controls | NYHigH | 5.0 Mustangs | 2 | December 27th, 2006 10:48 PM |
| Heater/ac controls........problem? | Bossman | 2005 - 2010 | 7 | December 27th, 2006 10:04 AM |
| Red Vs Blue | GTsetGO | The Clubhouse | 9 | August 30th, 2006 07:37 PM |
