setting TPS Hi All... I was adjusting the TPS to 0.98 but couldnt go any higher then 0.86. i been trying all morning but to to no success can leave it there or is there another way to get 0.98 and my idle is at 1200 RPM is that normal or to high
That's high. Are you sure you're doing it correctly? Why can't you get past .86V? Do you not have the space to move it anymore or what?
well you have to drill out the screw holes to get it to move more BUT wait for some of the other guys get on they will explain to you why setting your TPS doesnt matter
#4 | |
i got the tps at 0.98 now i drilled the holes wider but cant get it to lower the idle it stays @1200 rpm i unscrew the screw in back of the throttle body i got it as far as it goes if i unplug the Idle Air Bypass it goes to 800 rpm (the IAB is new)
have u tried this? http://www.moddedmustangs.com/forums...dle-vt268.html
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
i put this question in a different post dont think it will get seen soo im gonna beat a dead horse here and ask. do i put one lead in one wire and the other lead in the other wire from my digital multimeter?? im also guessing set dial on low low dc voltage?? im slow work with me here. lol thanks take care.
Threads Similar to: setting TPS
| Setting 5.0 Idle | IcantDo55 | 5.0 Mustangs | 13 | July 28th, 2010 01:20 PM |
| Setting Idle | 91foxhatch5.0 | 5.0 Mustangs | 3 | July 5th, 2007 01:05 AM |
| Setting rev limit on MSD box? | gregkelley | 5.0 Mustangs | 14 | April 22nd, 2007 10:22 PM |
| TPS setting.....I hope?!?!? | chase | 5.0 Mustangs | 2 | March 9th, 2007 05:24 PM |
| Setting the timing? | MySallyMI | 99-04 | 10 | August 11th, 2006 01:10 PM |
