Back spacing
Old August 29th, 2007, 11:58 PM   #1
Stangzilla's Avatar
Stangzilla is on a distinguished road
Back spacing
I am buying new rims and tires soon and I need some help guys. I am finally getting rid of my piece of shit 17inch rims and tires. I am puttin Weld Rodlites on. On the rear should I use a 15x8 or 15x9 for a 275-15 drag radial and what backspacing should I get so i wont rub anywhere? On the front I will be puttin on over the winter SN-95 brakes. Can I run a 15 inch rim with those brakes. I was told by someone that I have to us ea 16inch rim. That is fine but I just want to know. If not I will go 15's all the way around, if not I will go 15 in the rear and 16 in the front. Also what backspacing if any will I need for the front? Thanx in advance...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old August 30th, 2007, 02:24 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
15x8 = 5.5" backspace
15x9 = 6.0" backspace
15x10 = 6.5" backspace
You will most likely have to do some minor clearancing to the inside of the wheel well with the 15x8 and 15x9 wheels. With a 15x10 you need to bust out the 3lb mallet.
As for the front, I believe you need a small wheel spacer to run the 15" wheels.......at least on the Cobras you do. Backspace will depend on rim width. A 15x3.5 wheel will need 1.75 backspacing.
Old August 30th, 2007, 11:27 PM   #3
Stangzilla's Avatar
I dont plan on doin skinnies up front. I am gonna run a 6 inch wide rim with like a 225-60 on it. So if thats the case and I am gonna do the SN-95 brakes do I need to run a 16 up front? If so what spacing will I need for that?
Old August 30th, 2007, 11:53 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Good question. You will probably have to take some measurements.
Old August 31st, 2007, 12:34 AM   #5
Stangzilla's Avatar
Yeah thats what I thought... Thanks for the info on the rear though..
Old August 31st, 2007, 03:39 AM   #6
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
I have a set of 17x9 for all the way around and they dont rub. I have a set 99 15' v6 wheel on it until i get it painted and they fit fine over the front sn95 front spindles I am not sure what the back spacing is but i can mesure it if you need me too i had to remove the quad shock they don't do anything anyway.I will tell you 16" tires are more then 17" kinda a odd size.
Old August 31st, 2007, 06:50 PM   #7
Stangzilla's Avatar
[quote="86ttops"]I have a set of 17x9 for all the way around and they dont rub. I have a set 99 15' v6 wheel on it until i get it painted and they fit fine over the front sn95 front spindles I am not sure what the back spacing is but i can mesure it if you need me too i had to remove the quad shock they don't do anything anyway.I will tell you 16" tires are more then 17" kinda a odd size.[/
Old August 31st, 2007, 06:50 PM   #8
Stangzilla's Avatar
oops..
Old September 1st, 2007, 01:43 PM   #9
5litercobra is on a distinguished road
i just had a quick ? for darrell what is the wheel tire package on your stang cause thats the look and stance i want on my 93 coupe and did you have to tub it to fit those slicks on there or did you bust out the 3lb. mini sledge thanks.
Old September 1st, 2007, 03:51 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have 15x10 wheels in back with 6.5 backspace. I run a 28x10.5 slick. I stretched my factory wheel wells a few inches because I planned on running a 29.5x10.5W tire at some point in time but for the wheel and tire combo that I have on the car now it is unnecessary to stretch the wheel wells but you would need to modify the inner wheel well with a 3lb sledge hammer.
Old September 1st, 2007, 09:02 PM   #11
gotboost562's Avatar
gotboost562 is on a distinguished road
Send a message via AIM to gotboost562 Send a message via Yahoo to gotboost562
Good info. So with the same tire on a 15x8 or 15x9 would you still need to massage the inner fender well? What springs do you run at each corner?
Old September 1st, 2007, 09:10 PM   #12
93fourbangerstanger's Avatar
93fourbangerstanger is an unknown quantity at this point
i want your old rims
93 fourbanger /intake,exhaust,erg delete,8 inch sub...for now
fukin gas prices!
Old September 2nd, 2007, 11:32 AM   #13
thanks man also is it the stock width rearend do you run height adjustable control arms or did you lower it at all. I purchased eibach drag launch springs and lakewood 50/50 fronts 70/30 rears just wanting to know how you acheived that stance cause dam it looks good.
Old September 2nd, 2007, 01:19 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
My rear end is 3/4" shorter than a stock rear end on each side. I run coil overs all the way around and the car is lowered about 4 inches from the factory ride height.
Old September 2nd, 2007, 08:37 PM   #15
and now for my next question are the specs you gave for the rims for your application only or will they work with the stock width diff or would i need to narrow it so as to clear the outer fender well, since i would like to get as wide a slick as possible without a tub ,also do you use factory control arms or did you four link it or ladder bar it thanks man awesome info very much appreciated
Old September 3rd, 2007, 06:54 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I wouldn't put a 28x10.5 tire on anything smaller than a 10" wheel. Maybe a 9" but not an 8". Thin sidewall tire tend to be more unstable at high speeds on a smaller wheel. Either way you need to modify wheel wells. I run 90lb springs in the rear and 130lb springs in the front.
Old September 3rd, 2007, 06:55 AM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Those are the same size rims and tires I use on all my Mustangs. Fender lips will need to be rolled and the inner wheel wells will need some clearancing. Not a big deal at all. I run a stock suspension with Team Z Motorsports control arms.
Threads Similar to: Back spacing
Notch back or Hatch back ponyonsteroids 5.0 Mustangs 59 January 19th, 2012 06:49 PM
Bassani Axel back VS Magnaflow Axel Back.. What to get! myroush6 2005 - 2010 27 June 7th, 2010 04:51 PM
I might be back very soon mustangstud13 99-04 2 April 5th, 2007 03:11 PM
so a while back 232stang V6 Mustangs 7 December 7th, 2006 09:27 AM
Questions about Axle back & Cat back exhaust Scion V6 Mustangs 2 October 9th, 2006 08:44 AM
