Discussing Which would Win???? in the 5.0 Mustangs Forum. hey..i was talking to a friend of mine thats got a 93 hatch, and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1989 Mustang 5.0
dunno yet
Which would Win????
hey..i was talking to a friend of mine thats got a 93 hatch, and i was laughing at him a couple weeks ago cuz he's spent $5k just on appearnce on his stang and its NO GO..well i gues he's gunna show me up, well he pulled his motors ands dumping a 460ci big block into it..which will win, cuz were gunna take em unto new england drag way when he's done to see which is faster
His: 93 Hatch LX 88 F250 460 block bored .30 over edelbrock perfomer heads (not rpm's) edelbrock performer rpm intake holley 750cfm carb hooker headers custom x-pipe magna paks stock suspension and drivetrain stock AOD 4:10s Mine: 89 Hatch LX 302 shortblock ported and polished heads ported upper and lower 65mm TB and EGR 73mm MAF #24 injectors 1.6 roller rockers f303 cam manly stianless valves comp cams doubel valve springs shortys, O/R h-pipe, supper 44's short throw, aluminum driveshaft and loop, 3:55's bbk springs, kyb struts and shock, bbk upper and lower control arms full msd ignition.. well what im asking whos gunna win 1/4 miles, and a guess at some times...i read up on his block and stock there 275hp..he says his has 500hp (not rwhp) now!!! , probably doesnt but even with all my work he says im still under 300hp (flywhell hp)
new project..89 5.0 full restoration beginning.. |
Chicken Plucker
2003 GT
Well what kind of RWHP you at now
Military Crew ADAA Modular Mustangs are two damn confusing Crew Member #1 Founder
1989 Mustang 5.0
dunno yet
i would like to know..i dont have alot of the restriction in bewteen the flywheel and rear end that cuts off like 40-50hp..got dual friction clutch, light weight billet flywheel, aluminum driveshaft, new gears..would stronger axles helps that??
#4 | |
1989 Mustang 5.0
dunno yet
I think he has you.
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
The big block will win by a large margine. It is 450+ horsepower compared to your roughly 275 or so horsepower. His car if set up correctly will run high 10s all day long. At 3100 pounds and 450hp the formula says it will run 10.93 at 124mph. A friend of mine has a damn near stock 460 that just had a mild cam and with an Edelbrock intake and 850 Holley that runs 11.70s in a fox body.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
91 LX 5.0
11.87
I think you're toast
he wont hook up at all stock suspension in a car never meant to have a big block he will just sit there and roast the tires, where you on the other hand should hook up nicely
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
1990 LX hatch
The mid 70s and up lower hp rated BBFs, are still BBFs. All you need to make power from them is heads intake and a cam, even small spec. mods in those areas equal huge gains on the BBF. Never mind the HP rating for his motor, take a gander at the production TQ numbers. Your cars RWHP I am guessing 230-250.
![]() I <3 Econobarns AFR graph. |
Toss some Nitrous in there about 100 shot, you should do ok
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
#11 | |
1990 Mustang LX
9.36@143 mph
#12 | |
91GT, 88GT, 02GT
*Looking for a decent 90-92 Titanium hatch pull cover and retaining clips* |
1989 Mustang 5.0
dunno yet
well..his motor was out of a truck the same age as one me and my dad turned into a off roader, but it had no balls in that truck, and those truck motors are week, its an 89 460 that had like 165k miles on it before being bored out...and 275hp from the factory seams over rated for a truck of those years...
OK then if you think im toast, whats 1, i mean 1 thing that may even the playing field...nitrous, those trick flow heads, or what???
1990 GT
the miles on that motor dont really matter since it was rebuilt, its just a well seasoned block. and like they said above it doesnt take much to make power out of those big motors. i would add nitrous, that willgive you a lot more power for a good price
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
1984 FORD MUSTANG GT
well not that this helps at all but i just turned down a fox body with 460 in it ran good and had to have exhaust and had automatic, but i drove it and even with aftermarket intake and carb and headers, mine felt better and seemed more drivable. but is only my opinion. take care.
1987 ford mustang gt
well see when shes done
Youll prolly get your ass handed to you.
#17 | |
1989 Mustang 5.0
dunno yet
o i found that im gunna get my ass handed to me if it goes down, cuz he just bought a NOS 150-200 shot of nitrous for it...or i could win when he blows it up..
150 shot isn't going to do much to a 460 man..
#20 | |
1990 Mustang LX
9.36@143 mph
