just bought 86 stang...need some mod help please~!
Old August 31st, 2007, 06:10 AM   #1
djsylert is on a distinguished road
ok heres the deal, i bought a bone stock 86 mustang today... gt 5spd...realistically i have upwards of 5k to throw into it...im looking for power, i.anyways im concerned about the engine, i wanna do heads, cam, upper and lower intake, rockers rods throttle body exhaust etc..basically looking for an all around good setup without touching the main block or crank...i dont want to end up buying parts that dont match up right...if someone could give me a setup they think would provide the most power....id appreciate it. ive looked and see to get 3.73 gears and cai h/c/i but i wanna know specifics so i know im building the right setup.
Old August 31st, 2007, 11:48 AM   #2
1993 5.0 notchback
91 5.0 lx hatch is on a distinguished road
summitracing.com or jegs.com they got good power packages for mustangs
Old August 31st, 2007, 12:04 PM   #3
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
if you bought it from a seller you dont know, i would most likely rebuild it then work from there. so before the rebuild when its all taken apart you can get some fresh machine work done to the block and heads, unless you want to go after market with the heads.. that should only run you $600 or close to that. jegs has some nice gasket rebuild kits, then you should look into pistons of the size that you bore it out to i.e. .030, .040, .060. after that get the heads ported. before you get machine work def shop around and visit the machine shop to see how they do their work. after that you can go with a crane cam of your choice and some 1.7 rr from crane. if you do go aftermarket with heads you can shop around for some heads in jegs. ive heard good things about twisted wedge never used them though. you can go with a edelbrock intake manifold, possibly the victor jr series. when buying though do a little research about each product. dont jsut look for which one adds the most hp, matching products up correctly is a nother big factor. a good tuned car is a good running car ya know. best bet is not to rush into anything, dont go the cheap route cause youll jsut wind up having to do more to the engine and wishing you shoped around and went the best route. sorry to be brief with specific parts and all but i think you should shop around and do some research since its your car and all.
Old August 31st, 2007, 12:21 PM   #4
1993 5.0 notchback
if your in ca i can get edelbrock parts dirt cheap
Old August 31st, 2007, 12:41 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
I think you missed the part about him wanting to avoid doing any bottom end work
I guess doing the work twice would suck but I would say if it does not burn oil and a compression test is good, I would not assume the bottom end needs to be rebuilt unless you want to. You will be replacing the gaskets when you put the new heads on anyway. A little more involved but you can pay about $20 and have an an oil sample analyzed and diagnosed. The diagnosis is more accurate if you know how many miles that current oil has and what brand it is but either way, you will have a lot of useful information about the overall condition of the engine.
Old August 31st, 2007, 12:48 PM   #6
they do an oil diagnosis thingy..wtf..where
Old August 31st, 2007, 12:52 PM   #7
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
I will tell you this most people do not know in 86 they used 10:1 compression to do this they used flat topped pistions If you put a diffrent cam in a stock block it will be very bad. Now I do not know what cam heads you can get buy with comp cams might be able to help you out. I ended up calling them to buy a cam and they informed me of this 86 is the only year for this.I put gt40 ported and polished heads on mine and i am curently looking for gt40 uper and lower intake. for now
Old August 31st, 2007, 12:56 PM   #8
nolife's Avatar
91GT, 88GT, 02GT
http://www.blackstone-labs.com/ is what a lot of users on "Bob is the oil guy" forum use for testing. Have not done it myself yet though.
Old August 31st, 2007, 12:59 PM   #9
thats pretty sweet actually..but anyways..no i didnt know about that whole 86 compression deal..so you might as well rebuild it and do your own thing to the block.
Old August 31st, 2007, 06:20 PM   #10
thank you for all your help...i was looking into the twisted wedge top end kit heres the specs:
Trick Flow Top-End engine kits provide dyno-proven power without the guesswork. Built around Trick Flow?s Twisted Wedge cylinder heads (TFS-51400004), the kits include a specially matched hydraulic roller cam (TFS-51402000), roller rockers (TFS-51400510), gasket kit (TFS-51400904), timing chain, pushrods (TFS-21406700), and short valve covers. Lifters not included.
TFS-K514-350-370, 350hp/370ft.-lbs., kit
Kit Contents:
TFS-51402000 Hydraulic roller camshaft, each
TFS-51400510 Roller rocker arms, set of 16
TFS-21406700 Chromemoly pushrods, set of 16
TFS-51400904 Gasket kit, each
TFS-51400801 Silver valve covers, pair
TFS-51400004 Twisted Wedge aluminum cylinder heads, pair
TFS-51500001 EFI intake manifold, silver upper, kit
ARP-154-3601 Head bolts, kit
TFS-51400800 Oil fill kit
TFS-51478520 Billet timing chain, set
FEL-TCS45449 Timing cover, set
NOTE: Kits were dyno-tested on a 306 cubic inch engine with 9.5:1 compression, a 70mm throttle body, 24lb injectors, 190 lph fuel pump, mass air, and 10° base timing.
now im assuming the kit doesnt come with the injectors throttle body etc...but another concern thath i have is the exhaust, i want to to bbk longtubes but will they match with the outlets on the heads? if so this seems like a great deal...and would i need to change anything else in the process or will that work out ok? and obviously gears but im going with 3.73's because i wanna save a little gas!
Old August 31st, 2007, 10:26 PM   #11
13.64@101mph
well you guys didnt relize in 86, there fuel injected..
custom cam
twisted wedge heads
trick flow upper and lower
holley 75mm TB and EGR
24lb injectors
Headers
harland sharp, crane, ford racing, 1.6's or 1.7's
and 100-150 shot of NOS..
you could still do the 3:73s and suspension crap..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old August 31st, 2007, 11:23 PM   #12
yeah my 86 5.0 is the same as the 87-93 pretty much...
Old August 31st, 2007, 11:28 PM   #13
13.64@101mph
yeah same motor that basically it..cuz interior is completly dif and body is pretty different..but the 86 was there test motor for EFI..
Old August 31st, 2007, 11:47 PM   #14
im assuming they liked it! lol even though i have 25 less stock HP :-( booo hopefully you guys can help me through my resto project and see what becomes of this thing...i have the money sittin here i just dont know what to buy first! soo many options!
Old September 1st, 2007, 12:15 AM   #15
ok so i think this is what im gonna do...tell me if i need to change/replace anything...not based on opinion...more so because something wont fit or work...
should i get a cold air system like a mac?? or does anyone recommend something else?
BBK Egr Spacer, 5.0, 75Mm
BBK Throttle Body, 5.0, 75Mm
ASP Pulley Kit, Underdrive, Red Aluminum, Mustang
Ford Racing Fuel Injectors, 24Lb - 5.0L/4.6L 8Pc
**BELOW THIS IS THE TOP END KIT FROM TRICKFLOW**
TFS Twisted Wedge Cylinder Heads, pair
TFS 5.0L Track Heat Intake Manifold, set
TFS Hydraulic Roller Camshaft, each
TFS Roller Rocker Arms, set of 16
TFS Pushrods, set of 16
SUM-G6620 Roller Timing Chain Set, each
TFS Gasket Kit, each
TFS Silver Valve Covers, pair
**EXHAUST**
BBK H-Pipe
BBK Headers, Long Tube, 1 5/8, Chrome and im planning on going nutty with cherry bomb mufflers and have my friend do a custom (no)cat back setup...unless someone thinks im half tarded for that...
I took it all off the 50resto site where i plan to purchase everything unless someone knows somewhere else i can get a good deal. but please let me know what else i will be needing (only engine) tranny, suspension, and brakes are future worries
Old September 1st, 2007, 04:47 PM   #16
ttt
Old September 1st, 2007, 11:19 PM   #17
13.64@101mph
stupid to just do engine crap..trust me, some basic mods to the motor will make that thing haul ass anyways...do some suspension stuff, new rear gears, clutch, shifter and stuff like that..make it easier to drive and handle..and you can still do some engine mods
MAC or BBK Cold Air
65mm TB and EGR
Trick Flow Upper and Lower Intake
BBK headers
H or X pipe
cat-back
new clutch
rear gears
new springs
shocks and struts
and maybe some other stuff..but it will ride alot better, sound better and go better..cuz with that hole engine set-up w/ stock everything else..wont be so much fun to do anything but burnouts..unless thats all you wanna do..
Old September 2nd, 2007, 06:26 AM   #18
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
+1.....speedstang is on it just cuz you have 50000 horsepower dosent mean its gonna hook up or stop for that matter.....you can get a quicker car just by doing suspension work plus that work will also translate into better stopping power as well (obviously) cornering....
Old September 2nd, 2007, 11:09 PM   #19
no i understand what you guys are saying, im doing the tranny and suspension as well, but im looking for help with the motor...thats where the setup is vital to me, im getting my tranny rebuilt and a nice clutch setup as well as suspension work too but im looking for motor help!!
Old September 2nd, 2007, 11:20 PM   #20
radster87 is on a distinguished road
one thing for sure do the speed density to mass air swap. I think ford racing has a kit to do this. I modded my 86GT and it ran like crap because speed density reads vacuum not air flow. new cams cause a loss in vacuum which makes the car run rich with speed density.
with this much horsepower it is hard to act maturely.
Threads Similar to: just bought 86 stang...need some mod help please~!
JUST BOUGHT! SPF0percent V6 Mustangs 40 July 30th, 2007 01:51 AM
Just bought! SPF0percent Visual 3 July 30th, 2007 01:23 AM
Hi IM I need sum help just bought my first stang 2000 gt Killax15 99-04 8 July 23rd, 2007 12:44 PM
New member just bought my stang last week 05stang808 New Members Introductions 10 May 30th, 2007 10:21 PM
bought some new toys for the stang. GTsetGO 99-04 1 February 15th, 2007 11:47 AM
