1989 Mustang LX
Throttle sticking?
Sometimes when I'm driving down the road, when I let off the gas the engine will remain at the same rpm and even keep up the constant speed. I know my gas pedal isn't sticking and I just replaced the tps. Any ideas as to what it could be?
Jesse |
1987 Mustang LX
13.9@102.43
I'm having the same problem, im starting to think its the throttle bodty.. but im not quiet sure.
HONDA: Hold on, Not done Accelerating A girl's legs are her best friends, but the best of friends must part. LIVE Tag- foxbody87
Spray all the linkadge with wd40 see if that helps
take your TB off and clean the inside
could even be the maf.....
Big timin' in a small town
Do a BG throttle body clean out that might free up the butterflys a bit.
I have had this trouble and it turned out to be that my injectors weren't seated correctly. it was a speed density car though.
with this much horsepower it is hard to act maturely. |
13.64@101mph
im kinda having that problem too..when i get on the gas A little bit, it doesnt do anything, then a little further then it revs..it skips coming back down to when i let of gas pedal slowly..idk why..could it be the tps..or tb..
try moving the throttle with your hand on the linkage and see if it binds. then take the linakge off and use your hand again to open the throttle and see if it binds there. if not then the problem is in the throttle cable somewhere.
1986 Mustang GT t-top time piece! |
I had that problem..
I took the IAC off, and cleaned it out good with Carb Cleaner and it fixed the problem.. |
13.64@101mph
well my studders through the pedal..when i control the throttle w/ linkage attached..so tomorrow i'll try w/ the cable off..how hards it to change out a throttle linkage on these..off hand..
#13 | |
but hey at lest you got the problem fixed |
#14 | ||
My throttle used to get stuck when I let it sit at idle for 30 seconds, like it was hard to push.. I sprayed Silicon Lubricant on the throttle linkage at the throttle body, just went crazy (Probably shouldn't have.. oh well) and it fixed that as well. |
1989 Mustang LX
Thanks for all the input. I will definately give these a shot. Its a little annoying when you let off the gas and the rpm and speed won't drop.
Jesse |
Threads Similar to: Throttle sticking?
| Throttle Body Cable Sticking | AggieStang | 99-04 | 15 | December 6th, 2010 06:10 PM |
| sticking lifters | stephen | V6 Mustangs | 1 | October 18th, 2007 11:48 AM |
| Back breaks sticking | Juggalo_X | V6 Mustangs | 26 | August 31st, 2007 10:11 AM |
| Custom Brake's sticking. HELP! | 935.0 | 5.0 Mustangs | 1 | August 3rd, 2007 05:23 PM |
| Power Lock Is Sticking... | Itrorev | Audio/Video | 7 | March 16th, 2007 10:30 AM |
