Stock horse power info please
Old July 24th, 2006, 01:04 AM   #1
trebel14's Avatar
trebel14 is on a distinguished road
does anyone kno how many horsepower stock the 94-95 GT 5.0s have? also how many horse does cold air intake give? thanks alot.
Old July 24th, 2006, 02:55 AM   #2
dcraig8 is on a distinguished road
94-95 5.0 had 215 h.p. the 5.0 h.o. came with 225 h.p.
Old July 24th, 2006, 03:22 PM   #3
5literJeff is on a distinguished road
Send a message via AIM to 5literJeff Send a message via Yahoo to 5literJeff
Everyone gives a different amount of horsepower for a cold air intake mainly because its hard to put a hard number on one.
If your engine air intake is terribly restricted in the way it is setup now and you go from that to a functioning cold air intake you will definately gain some power but how much depends on your other mods, the ambient air temperature, your elevation, your fuel air mixture, etc.
Also you will gain greater benefit from one during the winter when its scooping in 10 degree air then you would say during summer where you have 85 degree air coming in. But even 85 degree air is preferable to 110 or more underhood temperature air that you might be sucking up now.
When I used to race my supercharged t-bird (supercoupe) I would use a custom intercooler packed with dry ice at the track to give me up to an additional 4/10s of a second and 4 mph to my ET. However I was running a larger blower pulley for additional boost and the supercooling ability of that dry ice (dry ice has a surface temperature of -109.3 degrees Fahrenheit (-78.5 degrees C)) was a huge benefit for the 13 lbs of boost or so I was running. I also had a cold air induction that routed outside air on that car.
Is it worth spending the money to get one? Well thats up to you. I dont have a cold air induction on my mustang, but then theres alot of parts I am still considering getting.
Seat of the pants I would say a cold air induction is prolly worth 3-7 horsepower at higher rpm, if your current intake is restrictive. But like I said alot of factors could change that number and if you have a motor making big power that has an inlet restriction and you get rid of that restriction, you will see a bigger result.
Old July 25th, 2006, 02:18 AM   #4
trebel14's Avatar
ok thanks! alot of guys say it gives like 15-20....i thought that sounded a lil too good to be true,
Threads Similar to: Stock horse power info please
How Much Horse power do you have? Nameless122 V6 Mustangs 136 August 24th, 2007 05:21 PM
Estimated Horse Power Numbers? Darrellx14 5.0 Mustangs 5 August 23rd, 2007 01:29 PM
4.6L 32V cobra horse power CAP. Smoph 99-04 7 June 9th, 2007 02:45 PM
Mustang Horse power (2005 GT) Exseque Modular Mustangs 9 February 23rd, 2007 12:11 AM
Horse Power FTHOODV6STANG V6 Mustangs 25 October 15th, 2006 01:26 AM
