Discussing Squeals on startup in the 5.0 Mustangs Forum. I actually brought this subject up before, but the problem persists. When I start the ...
Old September 3rd, 2007, 06:41 PM   #1
Squeals on startup
I actually brought this subject up before, but the problem persists. When I start the car, I always get a squeal, which I assume is my belt slipping on a pulley. I have a Supercharger on the car, and as previoulsy suggested, I took the belt off of it. Still squeals. (Once in a while, it will squeal when I start to drive and lasts about 1 minute, then stops). It never squeals once the engine is warm, unless I turn it on, then start it again. I guess I can rule out bearings in the pulleys? I don't want to go to the expense of a new engine serpentine belt unless you guys think that will do the trick... Whaddaya think?
Old September 4th, 2007, 12:44 PM   #2
1993 5.0 notchback
from what you said. it sounds like your belt dude
93 5.0 notch-b303 cam,performer rpm heads,performer upper and lower,70mmthrottle body,shorty headers,h-pipe,flows,cai,1.7rr,built aod
91 5.0 lx hatch-Sold
92 5.0 lx hatch-Sold
Old September 4th, 2007, 01:07 PM   #3
FIVE-0's Avatar
Its the belt slipping on the pulleys, try adjusting the tensioner, otherwise your gunna have to pop for a new belt
Originally Posted by My'StangOpens
shuda gotta fox
now u cant be in the cool ppl group
im sry
Old September 4th, 2007, 01:19 PM   #4
yeaa it could be that or the belt is on there wrong. the car will still run but if its routed wrong it will squeel for a little bit then stop. i had that problem and when i took the belt off and put it on correctly it stopped.
Old September 4th, 2007, 10:46 PM   #5
Hmmm. Will try those suggestions. Today I squirted a little belt dressing, which I didn't plan to do, 'cause I was told it only gums the belt up. It didn't squeal the first time I started it, but an hour later on a restart, it squealed again. Hey, thanks for the reply guys.
Old September 5th, 2007, 12:07 AM   #6
im almost positive your belt is routed wrong.
Old September 5th, 2007, 12:27 AM   #7
I can't wait to see if you are right...I'll let you know tomorrow. I bought the car three weeks ago. Am quite happy with it, having moved up from a V6. Just started using this forum, and it's great having the input from fellow Stangers.
Old September 5th, 2007, 12:45 AM   #8
How old is the belt? Is it cracking?
Old September 5th, 2007, 12:46 AM   #9
I don't understand it could be routed wrong though.. On my 87, it can only be routed one way, or else the belt is just hanging loose and the tensioner won't even do anything..
Old September 5th, 2007, 03:57 AM   #10
when i had my squeeling problem i took it off and put it one back on and it stopped..the belt had no signs of wear..i was almost certain is was on wrong.
Old September 5th, 2007, 09:16 PM   #11
Well I looked at the belt and routing diagram, and it looks like it is routed the only way it could be. It is not exactly like the diagram though, because with the supercharger installed, the alternator is below it, and not where it originally sat. I suppose I will have to take numbers off of the belt and order a new one. When I bought the car, the engine area had been sprayed with something to 'shine it up', and I suspect that maybe if some of it got on the belts, this could have ruined the belt. I did wipe them off with brake cleaner, but no change.
Old September 5th, 2007, 09:17 PM   #12
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
it's a simple process.
it's either the belt it self or a pulley.
looks like you have done everything but replace the belt it self.
Old September 5th, 2007, 09:24 PM   #13
If it was a pulley, it would happen most of the time, wouldn't it? It only squeals at startup, and once in a while right after I start driving. Once the engine is warmed up though, it NEVER squeals. By the way, the belt looks fine, no cracks of frays at all.
Old September 5th, 2007, 09:25 PM   #14
HMUSN's Avatar
19.83 @ 12mph
it could be a bearing in one of the pulleys.
Old September 5th, 2007, 09:34 PM   #15
If it were a bearing it would be worse when hot...no?
Old September 5th, 2007, 09:35 PM   #16
HMUSN's Avatar
19.83 @ 12mph
I wouldn't think so.
I think it would be worse when cold.
heat makes things expand.
Old September 5th, 2007, 09:39 PM   #17
How would I know WHICH pulley?
Old September 5th, 2007, 09:43 PM   #18
HMUSN's Avatar
19.83 @ 12mph
get ears?
pop your hood and check.
worst come to worst go buy a stethoscope
Old September 5th, 2007, 09:45 PM   #19
1987 ford mustang gt
well see when shes done
347 stroker little street car yea its slow!!
Old September 5th, 2007, 09:47 PM   #20
I would have to be speedy gonzales, since the squeal only lasts one to three seconds.
Threads Similar to: Squeals on startup
Startup...ECU Keeps Resetting OcOnnor220 99-04 3 November 10th, 2007 01:26 PM
squeal at startup sasafrass12 94-95 2 August 18th, 2007 07:14 PM
5.0 Over reving on startup cptkng79 5.0 Mustangs 1 June 21st, 2007 09:59 PM
Startup Trouble DeathScythe95 V6 Mustangs 13 April 7th, 2007 08:19 PM
rattling after startup DeathScythe95 V6 Mustangs 25 February 14th, 2007 10:57 PM
