Discussing engine problems? in the 5.0 Mustangs Forum. Has anyone ever heard of gas being on there upper intake manifold gasket ? Or do ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
engine problems?
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
1993 5.0 notchback
i get small amounts in my upper intake but not alot just like a small coat
93 5.0 notch-b303 cam,performer rpm heads,performer upper and lower,70mmthrottle body,shorty headers,h-pipe,flows,cai,1.7rr,built aod 91 5.0 lx hatch-Sold ![]() 92 5.0 lx hatch-Sold
Verify your fuel pressure regulator is not leaking fuel through its vacuum line and being sucked into the intake. With only a small amount, it may be hard to verify. Do you have fuel or a strong fuel smell in the intake piping or around the throttle body as well?
1991 GT - Original owner, all stock 1988 GT - The project car |
1993 5.0 notchback
yea see i only have a little bit in the intake you can barely even smell it
Its a pretty big amount but I checked the vacuum line to the regulator and there was nothing there not even a smell. I think my injectors are to big I have 30pd injectors and I think I should of went with 24's.
Fuel on your upper intake sounds like a leaking injector or line.
2007 Explorer Sport Trac, 292 HP, Stock 2002 Mustang GT |
Threads Similar to: engine problems?
| Help! (Engine Problems) | 97ponylover | Modular Mustangs | 12 | March 18th, 2008 10:00 PM |
| engine problems? | B.A.M302 | 5.0 Mustangs | 7 | June 5th, 2007 12:27 PM |
| Engine Problems? | James | 99-04 | 10 | November 9th, 2006 06:20 PM |
| Engine Stalling Problems! | crewdog318 | 99-04 | 13 | October 13th, 2006 07:16 PM |
| Major engine problems, please help! | 03 R Code | 99-04 | 6 | August 25th, 2006 05:39 PM |
