hard shift
Old September 4th, 2007, 05:02 PM   #1
the tick is on a distinguished road
Send a message via AIM to the tick
hard shift
i have the WC t-5 in my 91 convertable and it seems to be shifting realy hard it started like a week ago jacked it up at my friends house checked the tranny fluid filled it with the suggested (a t f ) it went away now it started doing it again it wont go into rever and its realy hard getting in and out of gear i checked the fluid its full some one suggested it could just be a clutch and since its the stock i dont know how to adjust it or could it just be a bad clutch and suggestions on a good performance clutch that is still suitable for street
51-50'z ReSiN
Old September 4th, 2007, 05:30 PM   #2
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
Could be clutch out of adjustment or bent shifter fork in tranny or secronisers or how ever you spell it
Old September 4th, 2007, 05:34 PM   #3
1987 ford mustang gt
well see when shes done
just so you'll know i think its synchronizers
347, torn apart again.
Old September 5th, 2007, 02:05 AM   #4
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
smart ass....yea its prolly the syncros.....does your shifter have shift stops? if so set them better!
Old September 5th, 2007, 05:45 PM   #5
I wasnt meaning to be a smart ass.just wanted to let him know.Im sorry it came out that way.
Old September 5th, 2007, 11:43 PM   #6
i have no idea about tranny's so i dont know what a shift stop is and if the synchros were bad wouldnt it grind gears.?and when the car wasnt running it still wouldnt shift. plus after i let it sit for 3 days now i was messin with the shifter and it runs through the gears fine i havent driven it though
51-50'z ReSiN
Old September 6th, 2007, 12:37 AM   #7
IcantDo55 is on a distinguished road
You didn't happin to put in synthetic fluid, did you?
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old September 6th, 2007, 01:00 AM   #8
1993 Mustang GT
13.2 @98.54
FYI shift stops are located on the base of the shifter front and back and all it is is 2 screws that only allow the shifter to go so far......the way i set them is put the shifter in 3rd gear and set the screw so its just touching the shifter and then tighten then move the shifter to 4th and do the same....
Old September 11th, 2007, 01:50 PM   #9
what could happen if it was synthetic
51-50'z ReSiN
Old September 11th, 2007, 02:29 PM   #10
ryans88gt's Avatar
Does a stock shifter have shift stops? I don't know, I've never driven a mustang that still had the stock shifter.
If I had to guess, I'd say it sounds like the clutch is not disengaging completely. To test, put the car in neutral with the engine idling. Let the clutch out. Push the clutch in and wait 5 to 10 seconds and try to put the car in reverse. If it grinds going into reverse, your clutch is not disengaging. If it is smooth going into reverse, the problem isn't your clutch, which means it is your transmission.
Old September 12th, 2007, 12:23 AM   #11
ujslost's Avatar
reverse isnt synchronized. so check your clutch adjustment, this is acutally a common thing with t5 and t45s
Old September 13th, 2007, 01:53 AM   #12
where is the clutch adjustment. what would be a good stage 2 clutch to run, and whats the right fluid to use
51-50'z ReSiN
Old September 13th, 2007, 01:56 AM   #13
ujslost's Avatar
on the cable, and depends on it its stock quadrant or not
spec
atf (automatic trans fluid)
Old September 13th, 2007, 06:33 PM   #14
i know atf is auto tranny fluid but i know some fords take a specific kind. so whats the right one to use and what could happen if a synthetic is used. and does anyone know anything about ZOOM CLUTCHES?
51-50'z ReSiN
Old September 13th, 2007, 07:42 PM   #15
ujslost's Avatar
Ive had 2 zoom clutches, 1 was good, the other was shit, and they were the same exact clutches both times.
Threads Similar to: hard shift
How hard? D-Brow General Tech 8 November 4th, 2007 01:29 AM
It was so hard lol Timm10221 The Clubhouse 16 October 22nd, 2007 06:16 PM
how hard is it.. MSO The Clubhouse 31 September 11th, 2007 12:32 AM
Hard to please WAR-PARTY The Clubhouse 40 August 15th, 2007 12:58 AM
91 GT DOWN HARD SALEEN525 5.0 Mustangs 3 April 25th, 2007 12:26 AM
