5.0 Engine questions
What up people I own a 1993 Mustang GT. I just put in a pair of 275 50 15 M/T tires and takes off awesome. I plan on preping the car for a pair of AFR 185 heads. my questioin is what would I need to get before i can get these heads on? will the stock rotating assembly will be able to handle the heads.
suggestions on parts/combos would also be great
1987 ford mustang gt
well see when shes done
first off i what are you gonna do with the car?And how much do you have to spend b/c i could type all day.Is the car a five speed or aod
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
13.64@101mph
get cam, intake, injectors, TB, CAI, roller rockers...and stock rotating assembly will be able to handle those heads..
But it wont handle the valves,it has a 2.02 valve and stock pistons will only hold a 1.94
13.64@101mph
but your better off with trick flow twisted wedge heads..they allow you to run 2.02" valves on stock pistons with now work..unless you already have the AFR's..those are still great heads anyways..
#6 | |
13.64@101mph
347 stroker kit,afr 185's,custom cam 75mm tb,30lb injectors,100 shot of mitrous,1.6 roller rockers.
#8 | |
BUT i will be getting a bonus of about 2gs by December, and i am going to start to save up.
Isay trick flow kit with a s/c or nitrous since since you dont wanna take the bottom end apart.
well here is the car all bark and not that much bite.
*B4 the M/T Tires* ![]()
13.64@101mph
$ helps..but you gotta know where too look when $'s tight..swap parts is a good way..im pushing bout 260-270rwhp and i've spent only 2k on my car..thats mostly on visual stuff..you can do it with little to no cash..you just gotta be patient..but dont go cheap with important parts..
the 347ci idea is great idea..but not practical on a $300 budget jpjp..
I found my screen saver,are those 275 rears
#13 | |
On the last two pics they were 275/50 15.......SUV tires
HAH but the M/Ts are 275 and work great.
Threads Similar to: 5.0 Engine questions
| 3rd Gen mustang questions ew:engine mods etc... | skilzygw | 5.0 Mustangs | 1 | February 13th, 2007 10:14 PM |
| 96 To 99 Engine Swap Questions | smenzel444 | 96-98 | 66 | November 9th, 2006 01:49 PM |
| upgrades mainly engine questions! | 2001v6black | V6 Mustangs | 21 | October 22nd, 2006 12:26 AM |
| Engine Size Questions | shadowgames81 | All Other Vehicles | 2 | October 9th, 2006 04:01 AM |
| Engine rebuild questions | red stang | V6 Mustangs | 17 | July 15th, 2006 10:47 PM |
