Water Temp & Oil Pressure
Does the factory ecu use the signals from the factory sensors in any way? Or can they be removed to use Autometer senders for Autometer gauges? Thanks.
You can remove the factory sending units. The computer uses a coolant temp sensor which is a separate sensor from the gauge sending unit.
Threads Similar to: Water Temp & Oil Pressure
| Engine Temp | 00gtCoolGuy | 99-04 | 1 | October 18th, 2007 09:23 AM |
| Water temp sensor relocate? | ckjacobus | 96-98 | 2 | August 12th, 2007 09:56 AM |
| temp concerns | 95kystang | V6 Mustangs | 1 | June 24th, 2007 11:17 PM |
| water temp | coreyfitz | 94-95 | 1 | May 2nd, 2007 12:18 PM |
| water temp sending unit | Superfly76 | 99-04 | 23 | April 30th, 2007 12:01 PM |
