Transmission Help!!!
Hi everyone I am new to this forum and I have some questions for all you other Mustang nuts. I have an 89 5.0 with a lot of work done but I am running into some transmission problems and questions. I have an AOD and it is very built (red alto clutches and kolene steels) the whole works. But I am having trouble finding a valve body set up that works. I know the 91 and later AOD's have a 1,2,D, OD shift pattern. Would I be able to use that shifter and one of those valve bodies on my AOD trans??? Any help is very much appreciated as this is the only thing keeping me from being able to drive my car.
i answered this same question for you already in the other thread you made. get the AOD valve body the shift patter dont matter get an after market shifter and be on your way. then u will have full range selection. plz dont double post check back to threads you have created next time.
Well the only problem is no one makes an aftermarket shifter that has the shift pattern I want..My valve body and shifter as of now are set up 1, D, OD...But yhe 4 cyl's AOD has a valve body and shifter with the pattern of 1,2,D, OD...So on a 4 cyl you can shift all 4 gears individually...But on a V8 you can only do 1 3 4 so you lose the ability to keep it in second which makes drag racing a bear...
My Bottle Fed Pure Bred!!! |
took me 5 min to find an after market shifter for you.
google is your friend http://www.bmracing.com/index.php?id...bcat=1&pid=356 |
ouch
Yea I almost bought that shifter too...But it only does the 1, D, OD shift pattern and thats not what I want. I called B&M personally and talked to their tech dept. That shifter still does the exact same thing as my stock so I dont see spending $300 on it for still no 2nd gear...
#7 | |
ok drag shifter full gears select AOD compatible
http://www.bmracing.com/index.php?id...bcat=2&pid=344 ratchet shifter about the best kind you can buy |
See thats why I am confused I have a 1993 4 cyl Mustang with an AOD and it has a shifter that says 1,2,D, OD which means 1,2,3,4...But my 89 V8 says 1,D,OD so 1,3,4...So I have a 93 AOD with the shift pattern I want but obviously the bell housing is different...So I am trying to find out if I can use the 93 AOD valve body, shift linkage, and shifter to make my V8 shift all 4 gears seperate...But I dont know if the Valve bodies are the same and will work in either trans or not???
#10 | |
Threads Similar to: Transmission Help!!!
| Transmission | DirtyMach1 | 99-04 | 24 | November 12th, 2007 07:38 PM |
| transmission.................why god????? | Jeffery9508 | V6 Mustangs | 10 | November 10th, 2007 06:43 AM |
| AOD transmission | GT 5.0 | 5.0 Mustangs | 11 | September 24th, 2007 05:44 PM |
| Transmission | flamed 98 gt | 5.0 Mustangs | 9 | September 22nd, 2007 07:12 PM |
| transmission | new 5.0 | 5.0 Mustangs | 6 | December 20th, 2006 07:54 PM |
