install on bbk h pipe
Old September 5th, 2007, 10:29 PM   #1
dadslx is on a distinguished road
tonight i installed my bbk o/r h pipe everything was going great until i started the car and relized i had a big exhaust leak on the passenger side where the h pipe meets the header. due to fords wonderful donut design the pipes always leave a void for air to rush out of. i pulled the header off in hopes on correcting the problem, but i ran out of daylight. is there a metal filler piece or some type of gasket i can use to resolve this issue? i dont have transmission hangers for the exhaust they have been removed so that made things a touch easier but still have a nasty leak. i would love to hear some opions on this..thanks in advance!!
Old September 5th, 2007, 10:31 PM   #2
1987 ford mustang gt
well see when shes done
is it leakin at the header collecter,do you have any copper gaskets installed
347, torn apart again.
Old September 5th, 2007, 10:48 PM   #3
yes its leaking where the header and the h pipe connect ( collector ) the bbk doesnt provide gaskets and when i called ford to buy some they said they never installed gaskets on the mustangs at the the collector.
Old September 5th, 2007, 10:56 PM   #4
I have always used collector gaskets,whether i need them or not.
Old September 5th, 2007, 11:05 PM   #5
do you know of any that work with the facotry style 2 bolt donut collector?
Old September 5th, 2007, 11:18 PM   #6
autozone carries felpro gasket # 60924 im picking up some tomorrow..lol..thanks for the help
Old September 5th, 2007, 11:40 PM   #7
hope it fixes it for ya man.
Old September 5th, 2007, 11:51 PM   #8
nolife's Avatar
91GT, 88GT, 02GT
This may seen dumb but could the other side be too tight and not allowing the leaking side to make good contact? Try loosing up the non leaking side and then tightening both sides a little at a time.
Old September 5th, 2007, 11:55 PM   #9
thats actually a really good idea
Old September 6th, 2007, 12:28 AM   #10
nolife's Avatar
91GT, 88GT, 02GT
Its easier to get the h pipe lined up if you have the rest of the exhaust already bolted up where it should be. A small misalignment of the h pipe throws the whole thing off and you could end up with a tail pipe hitting the axle or rubbing on the tire. I haven't done that on my Mustang but I have on one of my cars with a single exhaust. I ended up having to loosen the two ball connectors, lining the entire exhaust up where it should be and then tightening everything back up together. Hopefully his problem is that simple and not a malformed H pipe.
Old September 6th, 2007, 02:09 AM   #11
408gt91's Avatar
408gt91 is on a distinguished road
i have the same set up on my car.you do not need gaskets.you need a big prybar.they never line up right. i had long tubes and shorty pipe on my 331 and did the same thing,i cut the hangers then i pryed the h pipe apart a little to get it to line up.i also just did the same thing to my 351 bbk set up. there 2 bolt ball flanges that do not need gaskets,the ball on the header goes inside the cup on the h pipe.
Old September 6th, 2007, 09:54 PM   #12
today after numerous attempts at solving the issue. i purchased ultra copper sealant which helped on the collector flange. The rear flange that connects to the muffler seems to be about 1/2 and inch too short. im going to remove the rear section tomorow and try again
Old September 7th, 2007, 04:40 PM   #13
408gt91's Avatar
sometimes you can bend the hangers an it will shift it enough,just make sure your tailpipes are even.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Threads Similar to: install on bbk h pipe
X pipe Install MnrlGry01gt General Tech 7 September 11th, 2007 01:58 AM
Header and X-pipe install AndyG47 V6 Mustangs 40 August 23rd, 2007 02:32 PM
HELP PIPE INSTALL!!!!! 02steedagt 99-04 26 April 29th, 2007 11:58 PM
x pipe install help chameleonaire 99-04 3 April 29th, 2007 02:06 PM
mid pipe install o3gtdgs 99-04 8 December 23rd, 2006 04:43 AM
