TFS Stage 1 cam?
Whats going on people. Does any one know where i can get this cam? Jegs, summitt?
summit owns trick flow, so I would say summit
Do you by any chance have the part number for the stage 1 cam? I see track heat and no stage 1.
Should i go with 1.6 or 1.7 rockers? heh any help would be great.
![]() Stock 5.0 Engine M/T Drag Radials E.T.- 13.859 MPH-97.23 60 foot-1.853 |
http://store.summitracing.com/partde...0&autoview=sku
I have no idea what you have done or what you are doing, so telling you which rocker is a crapshoot |
I got a 1993 Mustang GT Pretty much stock just has headers, ignition, 3.73s, M/T Drag radials.
![]() iTrader: 1 reviews
I have a brand new TFS Stage 1 Cam, with rockers? interested. I'm not sure if its 1.6 or 1.7 but it comes with the Street Heat Top End kit. I got pretty much everything except the Heads, let me know if your interested.. PM ME
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
#7 | |
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
#8 | ||
Alright I thought about it and i was thinking about a stage 2 cam whats the diff?
I want a real loppy idle. I am thinking about porting the heads and getting a 3-angle valve job, along with the cam. I also hears about shaving the bottom of the heads to increase compression. whats the difference between the stage 1 and stage 2 TFS cam? what rockers should i go with if i want the stage 2 cam?
1987 ford mustang gt
well see when shes done
Your better off to buy a set of heads.you will do nothing with the stock heads but spend alot of money and not even come close to the kind of power a set of aftermarket heads can give you.G trick flow twisted wedge heads
#11 | |
Like mentioned don't waste your money on stock heads. The middle TFS cam (stage 2) works really well in a street car with good heads.
new heads sounds like a big investment......BUt if they give you that much of an improvement .....its worth it!
......How much are they? (tax included) I was thinking about getting TFS TW heads or AFR 185. any one know the price on the TFS heads? I went to the site but couldent find the price. the AFR 185 are at 1,399.Will the stock 1993 internals be able to handle the new heads and cam? What size TB/ injectors/ fuel pump/ MAF should i go with? What rocker size should i use? I saw this article on the AFR site. http://airflowresearch.com/articles/...Part4/A-P3.htm |
Go with the tw heads b/c you can use the 2.02 valve with the stock pistons,as for the afr 185's you would have to flycut the pistons.There is nothing wrong with the stock internals on a 93 as long as you dont want to use nitrous b/c 93 was the only year that cama out with hyperutectic pistons they are great for n/a combinations but not great for power adders.hers a set of trick flow heads that would work nice with what your doing.
http://store.summitracing.com/partde...5&autoview=sku |
70 mm tb,24 lb inj,75mm mass air,190 lph fuel pump
#16 | |
Thanks for the advice. :award
Its alot to think about. Any one know the difference between the 1.6 and 1.7 rr? |
i would go with the Track Heat kit and get the Stage 2 cam.
1.7 roller rockers increase lift
Threads Similar to: TFS Stage 1 cam?
| Stage 0 SRT-4 | Mystry | 96-98 | 32 | December 1st, 2007 11:14 PM |
| Evo stage four kit? | cams-shelbycobra07 | General Tech | 12 | April 25th, 2007 12:22 AM |
| Which stage | WilltheThrill | Modular Mustangs | 6 | March 29th, 2007 01:05 AM |
| VT Stage I vs. Stage II | 68 dlxcoupe | 96-98 | 9 | January 24th, 2007 11:09 AM |
