#21 |
lol you make it sound so easy lol
#22 |
I will tear into it later on when it cools down and I ACTUALLY NEED to use the heater. For a temp fix I just connected the two hoses together using some pipe fittings.
In doing so I noticed the larger hose had a metal flow reducer in it. I thought only the SSP cars came with it. I cleaned it up as it had some rust on it and pitting. The rubber ring inside it is all cracked and looks like it could fall apart any minute. Should I reuse the reducer when I r & r the heater core? Can I just take the rubber ring out and not worry about it? |
#23 | |
You MUST use it. Otherwise it will blow up the new heater core soon and you will hear the water whistling when you drive. |
#24 | ||
#25 | |||
Threads Similar to: Heater Core
| Heater Core! | ujslost | 96-98 | 13 | November 18th, 2007 06:59 PM |
| 96 GT heater core replacement | pwmorgan69 | 96-98 | 3 | April 9th, 2007 04:58 PM |
| Heater Core | nHuman | 96-98 | 3 | January 5th, 2007 02:22 PM |
| heater core | JABES | 5.0 Mustangs | 6 | December 5th, 2006 11:26 AM |
| heater core | zhunter | V6 Mustangs | 2 | March 23rd, 2006 02:22 PM |
