Torque Box
Old September 8th, 2007, 08:23 PM   #1
gotboost562's Avatar
gotboost562 is on a distinguished road
Send a message via AIM to gotboost562 Send a message via Yahoo to gotboost562
Torque Box
I have seen different kits to strengthen the upper and lower torque boxes. Who makes the best one for the money? I have seen the bolt on ones but if it needs to be welded, that can be done as well. Thanks.
Old September 8th, 2007, 08:25 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Do not get bolt on ones weld them if you want them to help at all the bolt alow to much movment even if they are tight welds wont move
Old September 9th, 2007, 01:07 PM   #3
Is there a better set to get?
Old September 9th, 2007, 07:38 PM   #4
noyz25 is an unknown quantity at this point
BUMP to this post cuz i am wondering the same thing.
Old September 9th, 2007, 07:46 PM   #5
Drick's Avatar
This might help Click Here
Old September 10th, 2007, 12:02 AM   #6
ryans88gt's Avatar
I did the upper and lower on mine. As far as I know they all bolt in and then you have the option of welding. They bolt through the floor board, which is how they add strength. They work pretty well, but are a major PITA to install. Plan on having your car out of action for a few days, especially if you are welding. BTW I got the whole set for under $100 from Laurel mountain.
Old September 10th, 2007, 02:29 AM   #7
93'_GT's Avatar
93'_GT is on a distinguished road
JW do i need these? WHat happens if it does break? I got a 1993 GT pretty much stock 2-spd, 3.73s, Ford racin shortys, Lakewood traction action lift bars, KC Clutch, BBK SFC, 15x10 weld DL w/ MT 275/50 15 drag radials. I launch at about 1.5 - 3.5.
I have seen them but I have no idea what they are for.
Old September 10th, 2007, 05:23 PM   #8
1987 ford mustang gt
well see when shes done
All they do is strengthen subframes.I would buy some competition engineering subframe connectors first and if you wanted to buy a set of these.Subframe connectors are highly recommended.
347, torn apart again.
Old September 10th, 2007, 05:38 PM   #9
ryans88gt's Avatar
Ummm...no they have nothing to do with the subframe.
They keep you torque boxes from ripping. Your torque boxes are the points where the lower control arms bolt to the car. All of the drive force from your engine pushes the car forward at these points. Overtime they tend to flex back and forth enough that the metal and spot welds tend to break. Installing these will fix any looseness that is already there and help hold the torque boxes together.
Old September 10th, 2007, 05:43 PM   #10
My bad i have always been told thats what they did.thanx for explaining man
Threads Similar to: Torque Box
NEED MORE TORQUE!! Cantbeatblack 99-04 29 September 26th, 2007 09:32 PM
Torque??? jonnotch 5.0 Mustangs 4 April 2nd, 2007 11:47 PM
torque...? geofarrey V6 Mustangs 10 February 8th, 2007 05:54 PM
torque Rolis V6 Mustangs 14 December 10th, 2006 02:51 PM
Torque Stan27 General Tech 8 April 30th, 2006 02:00 AM
