question about intake fitting....
Old September 8th, 2007, 10:59 PM   #1
7-up man is on a distinguished road
ok, im in the process of putting my new engine in my 1990 LX. It has been several years since I had one of these cars and I cant remember what a certain fitting does in the lower intake.
If you are facing the engine from the front of the car, on the left rear corner of the lower intake there is a brass fitting with a post on it. Is this for the factory water temp guage?
Thats all I can figure.
Old September 9th, 2007, 12:18 AM   #2
cali 5.0 is on a distinguished road
wht kind of intake is it
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old September 9th, 2007, 01:14 AM   #3
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
post a picture its hard to tell what you talking about
Old September 9th, 2007, 11:18 AM   #4
408gt91's Avatar
408gt91 is on a distinguished road
that usually has a nipple with a small coolant hose that goes to your egr spacer.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old September 9th, 2007, 07:03 PM   #5
its a holley systemax, but this fitting is the same on the factory intake from what I remember.
Its not a coolant hose for sure. it has an electrical post on it.
im not technically savy enough to post a pic. I can take one and email it to someone so they can post it if possible?
Old September 9th, 2007, 07:09 PM   #6
Drick's Avatar
I would go with the water temp sensor is it round with an electical sensor
Old September 10th, 2007, 12:42 AM   #7
408gt91's Avatar
you said left rear corner,that lead me to think it was a coolant nip.
Threads Similar to: question about intake fitting....
cai fitting? Killer_Bee V6 Mustangs 5 August 6th, 2007 05:45 PM
Lowering Springs Fitting Question!!!! Slowbra_12 96-98 2 June 10th, 2007 11:34 AM
radio fitting 94grreenmachine Audio/Video 6 May 6th, 2007 08:19 PM
Carpet fitting RichM V6 Mustangs 8 April 29th, 2007 11:19 PM
grease fitting holtte 99-04 2 December 18th, 2006 09:50 AM
