Help carb'ed 302 /efi 302
So i bought a mustang ....
1995 Mustang (non/GT) the previous owner swapped in a carb'ed 302 out of a truck or something... Problem is the block is shot, oil and coolant shooting everywhere. I have an EFI 302 out of a lincoln Continental. My question is.... since i have 2 complete engines, what do i need to convert the EFI 5.0 into a carb'ed 5.0. reason is he cut the harness to shreds and rather than finding a new harness, i'll just go with what is in there. the 302 that's in the stang has a holley 750 and seems to be running pig rich. (i get about 80 miles on a tank) Here are my questions : can i use the EFI heads with the carb intake manifold ? would a 550 or 525 cfm carb help me lean it out a bit ? Thanks a lot ![]() P. |
1987 ford mustang gt
well see when shes done
The 750 is too much carb and eveything else should just bolt right up.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
that's what i figured, my 455 GSX had a 750 and it was just perfect for it.
So there shouldn't be any issues ports lining up ? |
just get a 600 cfm for it and it will be fine and yes you can use the same heads
A lower flowing main body has nothing to do with how rich or lean it is running. It could run just as rich with a 390 cfm carb as with a 1050 cfm dominator. Rich/lean is all in the jetting and air bleeds. With the same jetting a 750 will run much leaner than a 650.
The reason why you need a properly sized carb for the engine has to do with vacuum signal and the enrichment circuit working correctly. With too large of a carb the carb doesn't get enough signal and you get erratic power valve operation and crappy throttle response. Your 750 is probably too large for a 302, but properly jetted and with the correct low vacuum power valves you should be able to get it to run pretty well. |
WOW!,
the knowledge on this forum is great ![]() don't go too far guys, i may and will have more questions soon ![]() Thanks. |
