A/C and AIr Bag
Old September 9th, 2007, 11:24 PM   #1
gotboost562's Avatar
gotboost562 is on a distinguished road
Send a message via AIM to gotboost562 Send a message via Yahoo to gotboost562
A/C and AIr Bag
Two questions in one post:
I noticed the a/c clutch does not engage when I turn the a/c on anymore. Is there a fuse or fusible link that I am missing somewhere? I checked the fuses under the dash and they are all good. The vacuum lines only control the vents and not the actual clutch engagement right?
While driving around today I noticed my air bag light would blink periodically. It would blink five times, then a small pause and two times. Followed by a really long pause and then the same sequance. Is there some coe for this? ANy details?
Thanks in advance.
Old September 10th, 2007, 12:33 AM   #2
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
ya its a code but i dont know what that one is and check the low/high pressure switch on the a/c its on the passenger side by the fire wall the only two wire that plug in too the a/c lines and unplug it and put a wire from one termanal to the other on the plug side if it comes on its ether a bad high/low switch or refregerent is low
Old September 10th, 2007, 12:47 AM   #3
If the refrigerant is low, the clutch won't engage?
Old September 11th, 2007, 02:11 AM   #4
Here is a listing for the air bag codes:
http://www.veryuseful.com/mustang/te.../airBag92.html
Anyone know where I could find the Rotunda Air Bag Simulator 105-00008 or equivalent?
I may just pull the air bag light and sensors if I can't fix it.
Old September 11th, 2007, 02:43 AM   #5
86ttops's Avatar
n/a
ya if its low enough no worky
