Under/Over rated heads
Old September 11th, 2007, 11:24 PM   #1
powersrj is on a distinguished road
I have been doing some research on a 427 build I would like to do from a 351 block. And I have decided to go with 225 series heads. I have compared the AFR's, Trick Flow, and Dart. I have always been told AFR's are the way to go, but after researching, AFR's come in dead last in flow charts, combustion chamber sizes, and exhaust port sizes. Second is Dart and first place is Trick Flow. Does anyone have any thoughts on this topic. Hopefully i get some good feedback on this. Has anyone actually seen an AFR or Dart head out perform a Trick Flow in its matching series. I.E 225 to 225 or 205 to 205 etc. And lastly is there an even better head than Trick Flow?
Old September 11th, 2007, 11:35 PM   #2
woody1 is on a distinguished road
Flow numbers are a very small part of the equation. Numbers taken at 28 inch depression is not even close to a running engine. What are there no numbers at 50+ Inch like on a running engine? Noone knows since the testing equipment is nill. What are you trying to do first off? Make 800+ The TFS and AFR will outperform the Darts, thats been proven time and again on running combinations, not that the dart is bad, by no means, but lets be realistic, are you building a class car? I mean if there is no limits then run a CFE Pro King head, how about a CHI, how about a Victor Glidden etc etc. Any of those 3 heads will be more than 99% of what people can handle. If it were me, it would be a TEA TFS, then the AFR
Old September 11th, 2007, 11:52 PM   #3
Its an 800 hp application and what is TEA?
Old September 11th, 2007, 11:55 PM   #4
Im intrigued, your shooting for 2hp per inch, tell me more about your goals etc.. Total Engine Airflow
Old September 11th, 2007, 11:58 PM   #5
Im so far away from even being able to put everything down on paper. I cant make hard decisions on many things. I just think its better to research it all before I just go have some one build me a blown 427 motor.
Old September 12th, 2007, 12:04 AM   #6
Just ask yourself if you have 12k+ dollars, thats the hardest decision, if you got that, its easy
Old September 12th, 2007, 03:05 PM   #7
ryans88gt's Avatar
I was just curious what you mean by this. 30 in Hg is complete vacuum. A difference of +50 in Hg from intake port to chamber would only occur if you were running 10 lbs of boost (-20 in Hg) and the engine was capable of creating complete vacuum (+30 in Hg) for a total of 50 in Hg. But that condition would only exist for a mere instant when the intake valve was opening.
What exactly do you mean? There are a lot of gaps between flow numbers and hp numbers, but I'm not sure I understand this one...???
Old September 12th, 2007, 03:49 PM   #8
I second that question.
Threads Similar to: Under/Over rated heads
Tire review// Hankook R106 V rated JASonic Parts 1 September 24th, 2007 08:42 PM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 09:34 PM
X-RATED RIDDLES WAR-PARTY The Clubhouse 6 July 18th, 2007 01:01 AM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
