Head gasket
Old September 12th, 2007, 11:57 AM   #1
nasty92LX's Avatar
nasty92LX is on a distinguished road
Head gasket
I blew my headgasket about a week ago .I bought the felpro mls head gaskets. They gave me a 4.200 bore size when a stock 302 is 4.000. Will this be ok.
Old September 12th, 2007, 12:29 PM   #2
13.64@101mph
wait when a engines bored .30 over, doesnt that calculate to a 4.030 bore..well if you're saying 4.200 that means a 200 overbore..or am i just that confused right now..and just have the engine bored to fit the gaskets now..
jpjp i think that the gasket being bigger than the cylinders, will make it leak..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old September 12th, 2007, 12:30 PM   #3
13.64@101mph
i think if it was opposite way, gasket smaller than cylinder than it maybe able work..but not in ur case..
Old September 12th, 2007, 12:36 PM   #4
nasty92LX's Avatar
someone told me it will work fine it just will lower the compres.
Old September 12th, 2007, 01:28 PM   #5
woody1 is on a distinguished road
it will work but I wouldnt use it personally, go get a 1011-1, a typical 1011 fel pro head gasket, .041 thick has a bore of 4.100, yes it will lower the compression
Old September 12th, 2007, 02:11 PM   #6
nasty92LX's Avatar
i already put it on the car
Old September 12th, 2007, 03:11 PM   #7
ryans88gt's Avatar
Don't worry about it, it might lower your compression from 9.20:1 to 9.18:1 or something like that. you talking about an additional 1/2 cc or less. It should work fine on you car.
Old September 12th, 2007, 03:19 PM   #8
ryans88gt's Avatar
OK, I did the calculation for you.
With a 64cc head on a 302 with a 4.1 head gasket and 0 deck and 0 chamfer you would have a 9.51 compression ratio.
Same combo with a 4.2 head gasket = 9.46:1
Old September 12th, 2007, 04:07 PM   #9
nasty92LX's Avatar
okk what do you put your heads to. I did mine from the inside out side to side 25lbs then 45lbs then 70lbs.
Old September 13th, 2007, 05:25 PM   #10
ryans88gt's Avatar
Mine are torqued to 125 ftlbs. But they are Cleveland heads, so.... anyway.
It depends on what heads you are using, what gasket, etc...but 70 ftlbs sounds about right for a stock motor.
Also, don't forget to do a retorque...most head gaskets these days let you do a cold retorque, but you should read the instructions that should have come with the head gasket.
Threads Similar to: Head gasket
Head gasket size 82 302 dreamr General Tech 1 October 30th, 2007 09:05 PM
=( blown head gasket itschristorres8 V6 Mustangs 17 October 23rd, 2007 12:14 PM
head gasket popmyclutch V6 Mustangs 14 September 12th, 2007 11:48 PM
99 3.8 L Head Gasket? Mike s V6 Mustangs 11 November 13th, 2006 04:51 PM
head gasket cali 5.0 5.0 Mustangs 3 June 20th, 2006 04:33 PM
