Straight Pipes?
Old July 26th, 2006, 06:40 PM   #1
Mystry's Avatar
03 Mustang GT
Mystry is on a distinguished road
Send a message via AIM to Mystry
Straight Pipes?
I just put straights on my 4.6 but my buddy likes how mine sounds, so he wants to do the same with his 92 LX, 5.0. I got him an appointment. Will it sound good? or not?
Old July 26th, 2006, 06:44 PM   #2
mdvaldosta's Avatar
11.47@120.58
What do you mean by straight pipes? No mufflers? Mid-pipe with no crossover tube?
Old July 26th, 2006, 06:46 PM   #3
Mystry's Avatar
03 Mustang GT
Yea just take out the mufflers and put a crush bend in the pipe you put in place of the mufflers so you dont lose too much back pressure
Old July 26th, 2006, 07:57 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No mufflers? Sounds like a dump truck and you like it?
Old July 26th, 2006, 08:14 PM   #5
Mystry's Avatar
03 Mustang GT
mine doesnt sound like a dump truck the slightest bit haha, idk how his will sound, but it couldnt be that much different
Old August 15th, 2006, 12:25 AM   #6
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
I have "straight" pipes on my (yall be nice it's my fiances car!!!!) 78 monte carlo,383ci.The exhaust runs from the headers to an "H" pipe to a glass pipe on each side then on out the back.Man that car sounds so sick.I've scared off potential "racers" just revving it in nuetral!!!!!On the other hand my 87 gt has a flowmaster force 3 cat-back system on it and it sounds good.Once i ditch the cats and put headers on it i'm sure it'll sound like it should!!! If you go with "straight" pipes you have to put an"H" or"X" pipe assembly on it or you lose too much back pressure and well you know what that means.And yes a 5 ohhh has enuff throat to sound good with "straight" pipes if its done right!
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Old August 15th, 2006, 02:27 AM   #7
5literJeff is on a distinguished road
Send a message via AIM to 5literJeff Send a message via Yahoo to 5literJeff
Someone else posted this link but I still think about it everytime I see a comment about engines needing backpressure, heh.
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
Old August 15th, 2006, 02:33 AM   #8
320hpPony?'s Avatar
Thanx for the clarification man,knowledge is power right? HP even if knowledge is used when building a motor i guess.Either way, appreciate the info bro!
Old August 15th, 2006, 10:18 AM   #9
Zak
Zak is on a distinguished road
Your friend can go with straight-through pipes using exhaust inserts from Car Chemistry to "tune up" that drone noise generated from removing the mufflers. Read this article http://www.fordmuscle.com/archives/2...ts/index.shtml
They're expensive though. Summit Racing carries those.
Threads Similar to: Straight Pipes?
X-Pipe + Straight Pipes = Nice Nasty Sound sorrowfulkiller General Tech 7 December 18th, 2007 10:53 PM
X, H, or straight pipes Nick_Rapitis V6 Mustangs 20 May 8th, 2007 03:11 AM
Straight Pipes XxMUSTANGxX General Tech 2 April 1st, 2007 11:16 PM
Straight Pipes rebelplayer2211 General Tech 1 March 25th, 2007 10:33 PM
Straight pipes??? V6RedMustang V6 Mustangs 35 February 1st, 2007 02:31 AM
