bigger is better . . . . right?
Old September 13th, 2007, 08:06 PM   #1
baine21225's Avatar
well i don't know if you guys remember me but i'm the guy who's puttiing the 700 hp chevy 350 in the 91 gt. i have about enough money to buy the conversion kit (k-member, coil overs, trans mount etc..) and get started on the swap. then i began to think that i'm most likely not going to get much traction with that kind of power. sooooo how much work, tools, parts, fabrication and and stuff am i looking at to fit 10, maybe 10 1/2 inchers in the back...i would really like any pics or videos of anything that people have done in the past themselves ...maybe i could follow it doing my own. thanks for the help guys. dont be too harsh on me
Old September 13th, 2007, 10:37 PM   #2
ryans88gt's Avatar
27 x 10.5 tires fit fine on a 4.5-5.5 inch backspace 15 inch wheel.
LXs sometimes fit 28 tall tires.
I have 26 x 11.5 ET streets in my stock wheel wells with a 9 inch wide prostar with 5 inchs backspacing.
Old September 13th, 2007, 10:37 PM   #3
baine21225's Avatar
COME ON !! ! ! I NEED HELP! ! ! !
Old September 13th, 2007, 10:40 PM   #4
baine21225's Avatar
forgive my ignorace, i've never done anything with the wheels/fender wells what is back spacing?
Old September 13th, 2007, 11:51 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
A 28x10.5 slick fits on a 15x10 wheel with 6.5" backspacing on any 79-93 Mustang. If you can't hook a 28x10.5 slick then you have issues elsewhere. You will have to roll the fender lips and do some work to the inner wheel well with a 3lb mallet. You will also have to watch the front and rear portions of the quarter panel if you exceed 140mph due to tire growth.
Old September 14th, 2007, 12:01 AM   #6
ryans88gt's Avatar
backspacing is the distance from the mounting surface of the wheel to the back edge of the wheel. Basically the higher the backspacing, the further into the wheel well the wheel goes. It is important to get the right backspacing when you buy wheels, or no tires are going to fit correctly. 5.5 inch is a good starting point. Really fox mustangs have a pretty good wheel well. 26 x 11.5 tires are good for like 1.4 60 foot times or better. Then again people are running 9s in the 235 drag radial class, so...you really don't need to put a big tire on there.
Darrell, I am assuming because you have 9 inch ends on your housing that is why you need 6.5 inch backspacing. Or do you have it mini-tubbed? For most mustangs a 6 inch backspacing will put the wheel right up against the inner wheel well. 6.5 would cause some serious issues. My street tires are on a 5.9 inch backspaced wheel and I had to do some inner fender massaging to get those to fit.
Old September 14th, 2007, 12:06 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've used 6.5 backspace on 15x10 wheels on every Mustang I've owned. You do need to massage the inner fender well a bit but it takes about 15 minutes per side. My current car doesn't count because the rear end is narrowed and it is mini tubbed but the last 5 or 6 Mustangs I've had have all used a 6.5 backspace.
Old September 14th, 2007, 12:12 AM   #8
baine21225's Avatar
so is it going to be possible to get 10 1/2 in there or should i jut go with 10?
Old September 14th, 2007, 12:35 AM   #9
ryans88gt's Avatar
Do you mean 10 1/2 in wheel?? It will stick out at least 1 inch further than it should and you will run into fender lip issues with a tall tire. But yeah, it can be done.
You only need a 8" or 9" wide wheel for 11.5" slicks...
A 10" wheel with 5.5" backspace will look OK, 6" backspace would be ideal, but you'll have some rubbing issues.
Old September 14th, 2007, 12:58 AM   #10
baine21225's Avatar
so let me see if i have this right. i can buy a set of 9 in rims for the back and backspace them 5.5ish and a i'll be able to fit a set of 11.5 wide slicks on them....with a little "inner fender massaging"
Old September 14th, 2007, 01:04 AM   #11
baine21225's Avatar
if i could fit 10 in rims i would like that better
Old September 14th, 2007, 10:51 AM   #12
1987 ford mustang gt
well see when shes done
Your hard headed.lol just j/k
But really your gonna have problems if you stick 10 inch wheel under there,9's look just fine.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old September 14th, 2007, 01:20 PM   #13
baine21225's Avatar
what is the difference in these rims
http://store.summitracing.com/egnsea...2&autoview=sku
and would these tires work with it
http://store.summitracing.com/partde...5&autoview=sku
Old September 14th, 2007, 01:42 PM   #14
You dont need to be building a car if you didnt recognize the difference in those 2 wheels.One is a 5x4.5/4.75 bolt circle and the other is 4x4.25/4.5 bolt circle.In other words one is five lug and one is 4 lug and yes the 275 drag radial would work but,i would use a mickey thompson not a bfg
Old September 14th, 2007, 02:28 PM   #15
baine21225's Avatar
shit, i feel like a complete ass.... didn't even look at the last numbers...do you have a link to the tires you would reccomend for those rims?
Old September 14th, 2007, 02:38 PM   #16
Not tryin to be a smart ass i as just stating my opinion.Give me a few minutes and ill get you a link.
heres a link of the m/ts i would run
Old September 14th, 2007, 07:59 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've never had problems with 10" wheels.
15x10 wheels are common on Mustangs.
Old September 14th, 2007, 08:17 PM   #18
You do have to roll the fenders and haft to have a 6.5 backspacing.
Old September 14th, 2007, 08:27 PM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes you do with a 10" wheel but that is not a big deal.
Old September 14th, 2007, 10:29 PM   #20
i know thats what i thought but was not sure
Threads Similar to: bigger is better . . . . right?
bigger wheels drazga97 99-04 1 November 10th, 2007 07:44 PM
Bigger MAF, Bigger Injectors??? oms4life 5.0 Mustangs 14 August 28th, 2007 10:47 AM
will i need bigger injectors? RyanGT 99-04 9 August 23rd, 2007 08:40 PM
bigger maf sensor gotime89 5.0 Mustangs 8 July 24th, 2007 09:06 PM
I want a bigger v6 99v6stang V6 Mustangs 60 January 15th, 2007 09:49 PM
