Missing a plug
Hi i just put a set of gt40-p head that have been ported and the explorer upper and lower on my car. The explorer lower seems like it does not have one of the plugs that the stock intake has. I have the temp and the plug that goes onto the heater core lines on both intakes but the one near the temp is not on the explorer. Will the car been fine if i do not have that pluged in.
Ok i found out what plug i am missing it is the ATC(Air Charge Temperature) sencer. Will it run right if i dont hook it up or do i have to.
1990 LX hatch
no it won't run right. If you relocate it to somewhere else in the intake track it will work, but the readings will be too cold and the ecu will give more advance. The proper way is to drill and tap the runner for the sensor.
will it be ok to put in on the intake tube
1990 LX hatch
yea it's just the scalers in the programming will be off a little, actually if you test the voltage range with the atc in the intake tube, and it is close to the values in the ecu it should be fine. Also that is one small part of the input the ecu uses to run your engine. I guess the botom line is it should work in the intake tube, but it will work if you drill and tap it in the runner.
yea i will put it on the intake tube. Right now the lower intake and upper are on the car.
wow, i didnt know all that...I just left my plug out! It seems to run alright though...Is there any long term damage here?
Threads Similar to: Missing a plug
| 97 V6 missing on cyl 4,5,and 6 | a_calm_victim | V6 Mustangs | 10 | July 5th, 2007 07:48 AM |
| Engine missing Q's | Rutcutter | 5.0 Mustangs | 21 | June 4th, 2007 05:05 PM |
| missing something and need a hand | extropy | Classic Mustangs | 4 | May 19th, 2007 09:50 PM |
| Car Missing Out Bad | bigbadtalontsi | 5.0 Mustangs | 7 | March 28th, 2007 05:14 AM |
| Car Missing Out | bigbadtalontsi | 5.0 Mustangs | 10 | March 11th, 2007 04:47 PM |
