p+p heads
does anyone know a rough estimate of the hp increase when you port and polish stock heads.
48.47@ 12.58
it really depends on a lot man.
meaning the type of port and polish. you might want to ask acmiller or boomer about it. they know quite a bit.
yeaa hopefully they will see this..by the way how have you been i havent talked to you in awhile..lol
48.47@ 12.58
start a thread in the clubhouse about that
SETTLED!!!!
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
It really depends on what kind of porting job you are talking about and what else you plan to change on your set up. You need to know exactly what you are going for before you get started though. That is the main killer of HP- People start just throwing known products together on top of a port job and sometimes those parts and pieces don't compliment each other. It would be nearly iimpossible to tell you a figure without knowing a few things first.
1. What are the spec.s on the cam you will be using? 2. What is your compression ratio. 3. What type/size of carb are you using. 4. Will you be using the stock valve train? 5. What kind of intake are you using? Even with all that info., the answer to your question would still be a guess. |
Threads Similar to: p+p heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 09:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 09:55 PM |
| 289 Heads | ezra27 | General Tech | 0 | December 30th, 2006 11:09 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 03:18 PM |
