High idle
Old September 16th, 2007, 05:18 PM   #1
8A_Honda is on a distinguished road
High idle
What all can cause it? IAC? Sticky throttle cable? Anything else? My cable seems okay and swapped the iac motor with one off another car. Not to say that one isn't bad as well. But idle won't go below 1500-1800 rpm. I can drive down the road at 25 mph in 3rd gear and not even have to press the gas and I'll stay the same speed without slowing down. Annoying. Clues anyone? Thanks.
Old September 16th, 2007, 06:06 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
tps?
Old September 16th, 2007, 06:09 PM   #3
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
when you are sitting still, rev it real fast and let your foot off the gas.. does that help at all?
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old September 16th, 2007, 06:19 PM   #4
sniperrider's Avatar
sniperrider is on a distinguished road
Send a message via MSN to sniperrider
vacuum lines or the idle screw.....ya never know
Old September 16th, 2007, 06:29 PM   #5
Originally Posted by HMUSN
tps?
I have a spare and I'll try changing it.
Doesn't help.
It started doing it right after I adjusted my timing. Only way I can get it to go down is by retarding the timing. Have new distributor and module on the car as well.
Old September 16th, 2007, 07:22 PM   #6
1993 notch
joe 5.0 is on a distinguished road
check your iming prol not set rite try retarding it a bit and see if that works had a similar issue with my car
Old September 16th, 2007, 07:42 PM   #7
When I retard it to get the idle down it's too low and doesn't wanna run.
Old September 16th, 2007, 07:51 PM   #8
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
What octane are you running?
Old September 16th, 2007, 07:59 PM   #9
93 cause I tried bumping the timing up to 14. Dropped the timing back down though cause idle went so high. But when I dropped it back down. The car barely wanted to run when I hit the gas.
Old September 16th, 2007, 08:04 PM   #10
Did you try that TPS yet?
Old September 16th, 2007, 10:49 PM   #11
Nah, about to. Had to go to town with my g/f. I know that the tps isn't suppose to be adjustable on a stock tb but do ya'll do it anyway if you're having problems or other mods that'd maybe warrant the need?
Old September 16th, 2007, 10:57 PM   #12
For a problem like you're having, it isn't a matter of adjustment.
Old September 16th, 2007, 11:16 PM   #13
Changed the tps. Didn't change anything. Ecu wouldn't need to be reset would it? I'd think that if it was the tps, that it'd just start running right if I changed it and it were the problem. Guessing I might need to go and pull codes.....again. Sigh........
Old September 17th, 2007, 02:32 PM   #14
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
i would of guessed it would be the idle screw. did you try that at all yet?
Old September 17th, 2007, 03:51 PM   #15
1989 Mustang LX
89StAngerLX is on a distinguished road
http://forums.stangnet.com/showthread.php?t=698148
Maybe this link will help. You might try cleaning your ten pin connector (white and black sensors on the back of the upper intake) like it suggest a little further down on the page. The white helps control several different things, the TPS being included.
Jesse
Old September 17th, 2007, 05:57 PM   #16
I didn't try that yet cause I haven't messed with it when the idle started going high. So wasn't thinking that would be it, being that I haven't messed with it. Figured it'd have to be something electrical and since it goes up and down with the adjustment of the distributor. The idle is constant though. It doesn't jump up and down. It's just that it's high.
Thanks for the link 89StAngerLX, I'll be checking all that stuff tonight. Of course pulling codes again will be the 1st thing.
Old September 17th, 2007, 07:53 PM   #17
I hate OBD1. Tried to do the codes and trying to figure out what the last codes are. This is how I counted it.
IIIIIIII / II / IIIIIIII / II / I / I / IIII / I / IIII
I gather that the 1st part is 82. But can't tell the part after that. 114 and 14? Just 14? Heck I dunno. Ughhh....
Threads Similar to: High idle
high idle RAMS#20 94-95 4 October 24th, 2007 02:23 PM
high idle then nothing msolaas1 2005 - 2010 4 October 10th, 2007 05:42 AM
high idle buddie 94-95 1 June 30th, 2007 02:40 PM
Idle Too High terribleonexx88 5.0 Mustangs 28 October 15th, 2006 11:27 PM
Idle Too High DaveCarey V6 Mustangs 14 October 11th, 2006 11:17 PM
