Low compression and low Octane?
Old July 27th, 2006, 08:08 PM   #1
brad65 is on a distinguished road
I think my motor is built having low compression. There was a blower on the car which I removed for many reasons. Anyway since I removed it I can run 18 degrees BTC with out pinging, even it 5th up a hill. But I'm still running one degree lower plug and 93 octane. The question hopefully you guy can help me with is.... Should I run 87 (regular) and get hotter plugs untill it pings. Would this be like getting more compression out of my motor?
1990 GT 306 fully forged, O-ringed Windsor Jr ported Alum heads, Edelbrook Performer, 1.6 FMSRR, E-303, FMS Shortys, 93 Cobra ECU, 24 lb, 93 Cobra MAF, MSD adjustable FPG, 3.73, stock h-pipe. Still slow.
Old July 28th, 2006, 11:44 AM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
changing your fuel will not change your compression...its only about efficiency to fuel burning
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old July 28th, 2006, 12:09 PM   #3
artisan00 is on a distinguished road
from what i understand, use the lowest octane you can without pinging. anything higher is a waste of money and less efficient...
Old July 28th, 2006, 12:26 PM   #4
mdvaldosta's Avatar
11.47@120.58
exactly. Put the stock heat range plugs back in it and bring the timing down to 10* and run 87... or put the timing wherever you want and start dropping the octane as low as you can.
Old July 28th, 2006, 05:05 PM   #5
I will try this and I'll let you guy know. Thanks
Old July 28th, 2006, 05:53 PM   #6
loudenough is on a distinguished road
Send a message via AIM to loudenough Send a message via MSN to loudenough
lower in types of gas will be harder on the motor as if not always detination will ocurr and will shorten the life of the engine.How ever you can run lower end gas and just throw so boosters in on fill up(most say 3 point min but I would dubble up on them to get the min)
Threads Similar to: Low compression and low Octane?
Octane Fastback91 Classic Mustangs 18 November 25th, 2007 08:48 PM
Octane vs Compression AnglicoGT98 96-98 18 September 18th, 2007 02:04 PM
93 octane? petrol_head 5.0 Mustangs 9 July 16th, 2007 09:12 PM
Gas octane ByPopularDemand V6 Mustangs 11 May 6th, 2007 09:30 PM
Which Octane? bostonbands 2005 - 2010 4 December 2nd, 2006 11:05 PM
